It died on me!
Old Jul 2, 2009 | 06:56 PM
Rocky5.9's Avatar
It died on me!
It seemed to start surging every time I'd get down to about an 1/8 tank. Got there on my way home from work and around the corner from the house...poof no rpms...no start.
Is it possible the fuel gauge is wrong....or the dreaded....vp death?
Thanks for any help.
Old Jul 2, 2009 | 07:22 PM
dodgerdog's Avatar
seems most likely that your fuel guage is off - the sending unit in the tank can and does go bad - take it from me . Meanwhile, I've installed an analog fuel pressure gauge as good measure especially with diesel - not good to starve the injector pump in that the fuel itself provides cooling to the injector pumps mechanical operation. the tank unit is about $70, but dropping the tank - now that is something I don't know how to do.
Old Jul 2, 2009 | 07:35 PM
babyjoe's Avatar
Definetly a bad gauge, I have been having the same dang problem First an 1/8 then 1/4. I hadn't drove mine for a month due to the transmission going out, got my new tranny and didn't remember for sure what it had in the tank but the gauge said 1/2 and it ran out on me AGAIN....I have got to do something about mine for sure...
Old Jul 2, 2009 | 08:15 PM
johnh's Avatar
if you run less than 1/4 ,you're asking for trouble
Old Jul 2, 2009 | 08:34 PM
babyjoe's Avatar
Why is that anyways...Would a draw straw help this and why is one needed I here alot about it....thanks babyjoe.
Old Jul 2, 2009 | 08:42 PM
Busboy's Avatar
As already stated the fuel is used for cooling the VP. The less fuel in the tank the hotter it becomes and lessens the ability to cool the VP.
Old Jul 2, 2009 | 08:46 PM
rich's Avatar
i ran mine low all the time on the 98.5 and put over 270k on the same vp. dropping the tank is very easy to do takes about 45 min to drop
Old Jul 2, 2009 | 11:45 PM
dodgeguy71's Avatar
I've got friends that run their stuff down to miles til empty using that contraption on the overhead console. I get down around 1/4 I realize I'm gonna have to fill it up anyhow, might as well be now. At least it won't look so bad $$ on the pump.
Besides, running it down low is that not where all the good stuff hangs out, water, trash etc, etc????
Old Jul 3, 2009 | 09:32 AM
klx650a2's Avatar
I had to replace my sending unit. Not a fun job on a rusted 9 year old truck. Took about 4 hours with the 2 of us (hmmm... there was some rye involved though). The inside of the tank was REALLY clean and no junk in the bottom. Keep in mind, if your sending unit is off, so is your miles to empty. When I dropped the tank, it said I had just under 3/4 of a tank and could go another 400 km, when I put it back on and replaced the fuel that came out, it said 1/8th and 122 km to empty.
When putting in the new seal, make sure it goes past the second lip or the lid will cross thread. Knowing that could have saved me an hour.
Old Jul 8, 2009 | 05:43 PM
Rocky5.9's Avatar
Thank you all for the advice....I put a few gallons in and got it running.
Tommy93w350
20
Nov 1, 2005 11:07 PM
Rigg4x4
Dec 13, 2002 01:40 AM
Desert Diesel
Dec 6, 2002 03:54 AM
Copenhagenjunkie
Nov 29, 2002 09:10 AM
