Cummins Engine Swap?
Old May 18, 2004 | 01:10 PM
mpfireman's Avatar
Wink Cummins Engine Swap?
I was looking at the Cummins engine web site, and saw the info sheet on the ISC engines. The 315 engine produces 315 HP & 950 Lbs Torque. or the 350 engine @ 350 HP & 1050 Lbs torque. The engine weight is 1,530 Lbs & takes 6.3 Gallons of oil. Now I know the ISB engine weight is 962 Lbs, or 568 Lbs less than the ISC motor. Now the question, Has any one seen a conversion from the ISB to the ISC engine?And if you have, what size truck would you have to use.
Ken
Old May 18, 2004 | 03:27 PM
There are pictures floating around of an F-250 with a C series Cummins shoehorned in. Lots of frame and suspension work, and the guy had to ditch the dash and build a doghouse. The C motor is just too big for a pickup, you need a medoum duty truck.
Old May 18, 2004 | 04:41 PM
BigBlue's Avatar
Why would you want to do that?
Old May 20, 2004 | 02:01 AM
kingofdodge7131's Avatar
only thing bigger than the 5.9 id wanna try would be the 8.3, have both in class and im not sure on weight but size isnt all that great. So it MIGHT be doable.
Old May 20, 2004 | 02:33 AM
Haulin_in_Dixie's Avatar
The C is about 4 inches longer than the B. It is also higher. Doubt that you could get it in a second gen. For one thing you would have to make a custom pan and pickup.
Old May 20, 2004 | 02:28 PM
BigBlue's Avatar
Hey Haulin, you should try it out. You've done everything else.
Old May 20, 2004 | 03:49 PM
smiller's Avatar
I have to second the question, why would you want to do such a conversion? Even if you were successful, nothing else about the stock truck would be up to what the new engine could do. You can easily mod the ISB to power levels beyond what the stock truck can stand... why spend the dollars to shoehorn in an ISC? If you need more hauling capacity it would probably be cheaper to just get a used MDT, which would have the added benefit of actually being useful for something.
Old May 20, 2004 | 06:06 PM
I could see no point to an 8.3. My current engine is basically stock (not Dodge stock) and is only running an EZ other than the intake and exhaust. It pulls as good as you could want. It gets great economy. Anything more would just be to accellerate faster, and the 8.3 will never be a 0 to 60 engine.
69fj2.5
Jan 31, 2011 05:06 PM
SWATPARAMEDIC
Oct 19, 2009 03:25 PM
bigwheels94
Jul 11, 2008 03:10 PM
Treangen
63
Jul 7, 2008 07:42 PM
TX_Diesel
Mar 31, 2007 05:30 PM
