clutch problems
Old Jun 14, 2009 | 09:04 PM
rholbus's Avatar
clutch problems
My trucks clutch will not disengage if I hold it in more the a few seconds.
The hydraulic fluid is full. Would this be my master or slave cylinder?
Old Jun 15, 2009 | 11:00 AM
Ruralmedic's Avatar
The hydraulic clutch system is replaced as a whole unit. South Bend clutch has them. When mine went bad, it was the master cylinder.
Old Jun 16, 2009 | 12:26 AM
cody_d's Avatar
I just did mine about a week ago, I was having the same problem you are describing. Slave/ master cylinder system. I went with South Bend, it has a braided stainless steel line (not plastic), came pre-bled, the hardest part was getting to old stock crap out with out breaking the line and leaking the brake fluid every where, and the top bolt on the master cylinder. The cylinders are noticibly larger than the stock. I did a few searches to see if I could find anything else out, and read a few times that the dealer part was more money. The south bend runs about $300 US
Old Jun 16, 2009 | 08:23 AM
rholbus's Avatar
Thanks for all of your help. I'll go check out South Bend right now.
DJ Turbo.
Oct 13, 2011 09:11 PM
Fishbait
Jun 6, 2006 12:34 PM
mbmrang
Jan 21, 2006 12:49 PM
kwhite4
May 9, 2005 03:22 PM
