head gasket
Old Jun 14, 2009 | 08:25 AM
johnh's Avatar
head gasket
it's about time.... i finally found the source of the coolant smell that's been present for a couple of years.
right under the thermostat housing i can see the antifreeze coming out and some stains.
so i ordered ARP studs and a victor gasket set off E-bay.....400 bucks for the studs and 315 for the gasket set........more than i expected, but it cannot be helped.
at least by doing the work my self i'll save a bunch....pictures coming later
Old Jun 14, 2009 | 08:53 AM
Copenhagenjunkie's Avatar
Have you hever had the head off before? That is a common leak spot, you probably already knew that. From your sig I wouldn't think you were makin that much boost to cause a leak.
I'm trying to remember, I had a leak there but it was a threaded plug which was behind a plate or something that was bolted to the t-stat housing, the stains ran down and made it look like the head was leaking.
Old Jun 14, 2009 | 04:09 PM
johnh's Avatar
never had it off before...i'll check the plug,maybe i'll get lucky,
I'll start the dis assembly in that area... i'll remove the alternator first to get a good view
Old Jun 14, 2009 | 10:40 PM
johnh's Avatar
Old Jun 15, 2009 | 06:11 PM
tractorguyacb's Avatar
wow that looks like AC refrigerant dye but we all know that it is not coming from that area. Good luck with this endeavor
Old Jun 16, 2009 | 09:25 AM
johnh's Avatar
i used some bars leak for my head gasket problem, it seems like it worked so far
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
blueberry
Feb 7, 2007 05:34 PM
Conn
Dec 29, 2006 06:30 AM
MADSEN
Oct 7, 2004 09:43 PM
