Click during Startup
Old Mar 23, 2004 | 02:04 PM
TurboPirate24v's Avatar
I'm in North Florida....and over the last few weeks for 3 or 4 mornings that have been
sub 40 degrees...I have experienced the following:
Turn the Key...Cycle...Turn the Key...Click.
Turn off....
Turn the Key...Cycle...Turn the Key...Starts Up...
Doesn't happen during the day or on mornings when the temperature is > 40 degrees.
Any thoughts...???
Old Mar 23, 2004 | 02:32 PM
BigBlue's Avatar
I think it might be the battery.
Old Mar 23, 2004 | 02:36 PM
Mexstan's Avatar
My first guess is that your starter solenoid contacts are shot. Next time you start up turn your headlights on first and have someone watch them while you turn the key. If they die then maybe you have bad batteries as well but the fact that it does start with no problems once it 'takes' goes back to the solenoid contacts. If they are the original contacts then they probably need changing anyway and updated to the better kind. Also check for corroded battery terminals.
Old Mar 23, 2004 | 02:45 PM
Well...
I've already checked that battery posts are clean and both my batteries were purchased within the last 18 months or so....and they are both overkill on the cranking amps...
So...sounds like my contacts...
Thanks for the comments.
Old Mar 24, 2004 | 08:28 PM
Geico266's Avatar
When I got my truck I had to have to towed in by the dealer about a week after I got it. Come to find out the factory did not tighten the nut holding the wire on the starter. I would start at the batteries and clean & tighen everything electical.
Starter solinoid would be my next guess.
marksmith
Aug 17, 2007 02:57 AM
Sleigher
Mar 23, 2007 12:23 PM
cheapskate
19
Dec 27, 2006 08:05 PM
PaulDaisy
Dec 2, 2006 12:36 PM
bnold
Apr 25, 2006 06:57 PM
