Cleaning Turbo Blades
Old May 15, 2003 | 11:07 AM
kstrongsyj's Avatar
When I took out the slincer ring on my turbo I noticed the blades are a little black and dirty. Is there anything in particular I need to use to clean them or is B-12 (or equivelant carb cleaner) ok? Thanks...I know its a dumb question
Old May 15, 2003 | 02:51 PM
moneyman's Avatar
Re:Cleaning Turbo Blades
THAT WOULD WORK JUST FINE
Old May 15, 2003 | 03:19 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Prop-Wash? a little Air Force humor
Old May 15, 2003 | 04:54 PM
DieselDaze's Avatar
That black residue you see on the impeller blades could be caused by an over oiled K&N filter.
This is what happened to me when I purchased a K&N filter that was over oiled from the factory.
It took me a full day to clean all the black residue off the impeller.
I used Q-Tips, brake cleaner, and rubbing aclohol to get the impeller clean.
(Make sure it has plenty of time to dry out before you fire yup the truck.)
The turbo pulls excess oil off the K&N and that oil sticks to the impeller where any fine dirt that makes it through the filter then stick to the impeller.
Rich.
Old May 15, 2003 | 05:26 PM
kstrongsyj's Avatar
Interesting DieselDaze.....I actually noticed it when I was INSTALLING my K&N ... Now I am eager to see what it looks like 5K miles later Thanks for the tips guys.....I plan to check it tonight and I will report back
Old May 15, 2003 | 08:59 PM
tmccormick's Avatar
Just a word of warning guys. Be very carefull while cleaning the blades because there is on some a white material which is used to balance the blades...you do not want to remove this material.<br><br>By the way I have run a K&amp;N filter since the truck was new and I have never had any oil on my turbo blades ;D
Old May 16, 2003 | 09:14 AM
kstrongsyj's Avatar
What I have isnt really oil persay....more like grime form 70K plus miles of use and abuse <br><br>tmccormick.....I havent been in there yet to look, but tell me more about this white stuff?? Is it a grease? Where is it?
Old May 16, 2003 | 07:28 PM
tmccormick's Avatar
You will see it on the turbo blade/blades when looking at the intake side. Not all of the blades will have it just the ones that required some weight. <br><br>It kinda looks like road grim but is white and a little rough if you rub your finger on it. It is usaully on the outer end of the blades. Again NOT all will have it.
Old May 19, 2003 | 10:26 AM
WA4SLC's Avatar
I also had some black deposits on my turbo blades when I installed my K&amp;N drop in filter. I just used a damp cloth to wipe mine off. I have not seen anything on my blades during the last year after I put the K&amp;N on. I ran across a good deal on a BHAF and holder along with a Mag-Hytec rear-end cover, they should be in this week, so I will see if the BHAF makes any diference.<br><br>Bill
Shrimp
Sep 20, 2007 09:16 PM
jeephauler
24
May 15, 2007 06:32 PM
Kuntry
Jul 11, 2005 05:02 PM
DZLPWR
Oct 17, 2004 07:27 AM
L. D. Bryant
Apr 16, 2004 07:39 PM
