Changing fluid nv5600
Old Sep 17, 2006 | 07:50 PM
ct2500's Avatar
how long are u going on fluid change for nv5600? thanx
Scotty
Old Sep 18, 2006 | 10:01 AM
dodgezilla04's Avatar
i had thought about that, seems to me that the most effective side would be the pass side, i think that is the direction that most of the g/o is thrown. but put the cooler or filter there?
Old Sep 19, 2006 | 07:27 PM
CTD2001's Avatar
How much fluid does the NV5600 take, thanks
Old Sep 19, 2006 | 08:01 PM
Sask's Avatar
I have the filter on the passenger's side - as per Geno's instructions - and one of the coolers on the driver's side. It clears the driveshaft on my 4x4 with no problem. The other cooler I mounted on the PTO plate to the transfer case - so I have a bit less than a quart extra fluid capacity in that unit, along with some small amount of cooling.
Old Sep 19, 2006 | 10:58 PM
Tiger Rag's Avatar
Boy, I don't recall a 17 mm hex anywhere on my NV5600? I just changes the fluid in mine for the second time. Just remove the bottom bolt on the drivers side PTO cover and drain. Replace bolt and fill through top bolt. Bolts are 15mm if memory serves. I jacked the drivers side up so I could over fill it. I believe its 4 qts std and 5 to overfill. Get that bolt in there quickly so you don't lose any. This is of course if you don't want to remove the PTO cover and clean the magnet. Fluid has been sqeaky clean every time I've changed it. I used Amsoil the first change but I didn't like how it shifted. I ran it 10k miles or so and replaced with Redline synthetic MTL which shifts much better so far.
Still wonder on the 17mm hex and the only thing I can think of is the transfer case?
Old Sep 20, 2006 | 02:18 AM
PourinDiesel's Avatar
No, theres a 17mm hex on the NV5600. Your just not looking hard enough.
Dr. Evil
Apr 1, 2017 02:54 PM
sshelly
Jul 17, 2003 06:36 AM
drafalske
Jun 15, 2003 01:55 PM
K2Cummins
Jun 6, 2003 12:18 AM
MikeyB
Apr 12, 2003 12:31 PM
