Brand new VP, got dead pedal and codes already..
Old Oct 10, 2006 | 09:28 PM
kxhonda's Avatar
Alright, so I have just about 4,000 miles on a brand new VP and lift pump, and now I am already having problems. My problems started this friday with the good ole dead pedel. It has never had a problem til then and I haven't had dead pedal since.
So tonight I decided to check for codes just for the heck of it. I end up with the the P0216 and P1688. I know these are the vp death codes but you got to be serious? After only 4,000 miles on a new VP and lift pump? Thats pathetic...
Well I hope the warrenty is still valid even after transfer of ownership...
Eric
Old Oct 11, 2006 | 09:13 AM
Mopar1973man's Avatar
Do yuo have a fuel pressure gauge at all??? You might of lost the LP pump and then lost the VP44.... Remember the LP pump could die at anytime...
I would try and use that warranty if you can...
Old Oct 11, 2006 | 11:28 AM
kxhonda's Avatar
I don't have a fuel pressure gauge yet. I figured with everything being brand new, I would be able to get away without one til I got the money. Guess not.
I did however hook up a guage under the hood and I had 9 psi at idle. But the hose was not long enough to get a reading while drving.
Old Oct 11, 2006 | 11:56 AM
Sask's Avatar
If you have 9 psi at idle, you probably have 2 or 3 psi at speed, and 0 psi close to WOT. And that's what happened - bad LP, bad pressure, and after 4K miles, a bad VP-44.
Old Oct 15, 2006 | 08:58 PM
possum67's Avatar
just a ? it only had 4000k on the pumps but how long since the fuel filter was changed
Old Oct 15, 2006 | 09:07 PM
DodgeCowboy's Avatar
DTR's Cow Boss
My truck as i sit now I have 10psi at idle and 6psi cruising and 3-4psi at wot so new lift pump is coming before i wipe the vp out of commission. I use to be the guy who said you don't need a fuel pressure gage but after installing mine and seeing the psi i have i would have done it sooner but glad i did before i ran around any longer with the numbers i have. On the note I agree with every one else money down you had a bad lp and after 4k mile of bad lift pump the vp finally had enough and packed its bags and hit the first horse out of town.
Old Oct 15, 2006 | 10:28 PM
kxhonda's Avatar
Well, I've got a campaign pump and vulcan kit on the way, hopefully it can still be saved. Filter was changed 3,000 mils ago.
But it just shows ya how crappy these lift pumps really are when you can't even buy a brand new one that works right.
Old Oct 15, 2006 | 11:33 PM
DTR's Cow Boss
there built by human run computers there is still the luck of the draw it happens with ever part you can go buy a starter and have it be bad from the get go.
Old Oct 15, 2006 | 11:59 PM
caleb's Avatar
if it was a new from dodge or cummins it should have a 1 year warranty on it, its a royal PITA because it takes them forever to refund you money... Does your VP have a warranty on it? I know when I went through this I made sure to buy one with a 12month unlimited mileage warranty but I lost that when I did the wire tap for the attitude/juice
Old Oct 16, 2006 | 10:24 AM
kxhonda's Avatar
Well, it was replaced at Haisley's by a different owner and I bought the truck right after the work was done on it.
Old Oct 16, 2006 | 03:52 PM
Forrest Nearing's Avatar
this is gonna sound wierd, but my buddy's 01 HO started having dead pedal issues... he was dealing with it for weeks, and he filled up w/ some B20 bio-diesel... he has never had the dead pedal since... he runs B20 whenever possible in the truck
Old Oct 16, 2006 | 10:41 PM
2 cycle oil does the same thing too...
Old Oct 17, 2006 | 12:49 AM
J BODY's Avatar
Black VP with "reman in CZ" stamped on it? also....you turning the key will show "stored" codes. If you use a DRB you will see how many key cycles since the code was set. The code you see may never have been cleared after the last pump was installed.
Hawkeye
Apr 17, 2012 11:50 PM
Opus
Mar 14, 2011 01:12 PM
600 Megawatts
Mar 26, 2008 07:09 PM
ncdodgeman20
Mar 19, 2006 09:36 AM
T6GPilot
Jul 15, 2005 06:47 AM
