codes and dead pedal
Old Mar 19, 2006 | 07:37 AM
ncdodgeman20's Avatar
can someone give me some help i posted on here earlier about the dead go pedal i just check the codes now it is troughing codes p1693,p0216,p0234and this sound really bad is it???
Old Mar 19, 2006 | 07:50 AM
Jetpilot's Avatar
The codes you show are indicating a failing VP44.....
Doug Smith
Old Mar 19, 2006 | 07:52 AM
crobtex's Avatar
Sorry, but the 216 is usually the death sentance for the VP44 (injector pump). The 234 is an overboost that might be caused by, or causing the 216. I'm sure others will chime in that have had the same codes.
Old Mar 19, 2006 | 07:58 AM
singleturnout's Avatar
iam trowing codes 0216 and 1693 i have a fuel pressure guage and its sitting at 20 psi and only goes down to 18 when i romp on it should i start saving for a new pump
Old Mar 19, 2006 | 08:45 AM
crobtex's Avatar
Some folks have run with the 216 for a long time before it quit on them. But, I would start saving for a new VP44.
Old Mar 19, 2006 | 09:07 AM
Unhappy
iam am also showing code p0234 a boost problem and someone said that can be causeing the p0216 code is there anything i can try or is it just on its way out???
Old Mar 19, 2006 | 09:13 AM
crobtex's Avatar
It MIGHT cause the 216. Erase the codes and see which ones come back.
Old Mar 19, 2006 | 09:35 AM
j-fox's Avatar
It looks like yout lift pump(transfer pump), is good, but the code says thereis a timing issue with the VP-44. This usually is a warning that it is dying.
Mine went 4-5,000 miles before I changed it out. It would have days of running ok, then some of real fits of smoke, shake, dead pedal. Notice I said running OK, this doesn't mean it was running good. I bought the Blue Chip VP-44 and am very happy with it.
Old Mar 19, 2006 | 09:36 AM
Ph4tty's Avatar
I don't see how overboost causes 0216. 0234 just means your truck ran more boost than the ecm allows, and when this happens the ecm defuels until boost drops to +/- 20 lbs and throws a code. Once you get your box/programmer the boost fooling these units do will eliminate that code.
Hawkeye
Apr 17, 2012 11:50 PM
600 Megawatts
Mar 26, 2008 07:09 PM
kxhonda
Oct 17, 2006 12:49 AM
reecegr
Aug 1, 2006 07:02 AM
T6GPilot
Jul 15, 2005 06:47 AM
