Dead pedal and codes?
Old Jul 14, 2005 | 07:43 PM
T6GPilot's Avatar
My 2001 has the dead pedal. I had the lift pump replaced a two months ago. Now I have the following codes. Not sure what the codes mean. Can anyone help decipher them?
Truck is all stock except gages for towing.
PPCU
P1693
P0216
P0234
Thank you
Kevin
Old Jul 14, 2005 | 07:52 PM
CTD2001's Avatar
P0216, Injection pump timing faliure, and the P0234 is turbocharger overboost,
I too just got the Dead peddle symptom a couple of days ago, I think the heat is bad for the computer parts of the Vp44 pump. There seems to have been alot of them failing recently with the warm temps. If you have under 100,000 on your truck, the dealer should replace the vp44 under cummins warranty
Old Jul 15, 2005 | 06:47 AM
CTD NUT's Avatar
For the most part, the 0216 DTC is all you need to know......it means your VP44 is getting ready to croak....as CTD2001 mentioned, get to the dealer asap if you are still under warranty so you can have that VP changed out.
Hawkeye
Apr 17, 2012 11:50 PM
600 Megawatts
Mar 26, 2008 07:09 PM
kxhonda
Oct 17, 2006 12:49 AM
reecegr
Aug 1, 2006 07:02 AM
ncdodgeman20
Mar 19, 2006 09:36 AM
