Big injection pump trouble maybe. Need help
Old May 25, 2004 | 03:53 PM
cumminsdriver635's Avatar
Unhappy Big injection pump trouble maybe. Need help
My uncle bought a 98 2500 4x4 quad cab, shortbed, 5 speed 24 valve cummins probably about a year ago. A while back it started smoking, and missing at higher rpm's. I told him it was probably his lift pump, so he ended up changing it, and everything was fine until now. You can still hear the lift pump running strong, but the truck is very hard to start. Right after he put in the new Lift pump, the truck took a little longer to start, but it wasnt near like it is now. Just recently it has started bieng very hard to start. My cousin(who drives it most the time) says it starts pretty good in the mornings when its cold, but that once it gets warmed up, it wont start to save its life. He said you have to crank it forever after it gets hot. Hes thinking that thew injection pump has went south, but it still has good power, and every time it starts, it shoots a nice puff of black smoke. The lift pump had probably been out for a while before he bought it, but it ran fine, so he didnt replace it/or really even know that they go bad easy. So my question is; do you guys think the Injector Pump has/is about to die? Or(hopefully) could it be something simpler and cheaper to fix? The truck has NO performance modifications, but it is straight piped, which shouldnt hurt a thing. It has probably about 130,000 miles on it now. Is there any codes that could be set off that we could check to see if that was the problem or not? If so, where could we have them checked? Thanks for any information, or suggestions.
Eric
Old May 25, 2004 | 04:48 PM
BigBlue's Avatar
Code P0216 is the Injection pump kiss of death. Sounds like the injection pump is dead if it's getting hard to start while warm. Almost a sure sign it's going out.
Old May 25, 2004 | 05:23 PM
Thanks for the reply. Where could we have the codes checked? Thanks
Eric
Old May 25, 2004 | 06:36 PM
BigBlue's Avatar
Autozone does it for free. I'm pretty sure just about any autoparts store will do it for free. Doesn't take them 5 minutes.
Old May 25, 2004 | 09:12 PM
Thanks. We might run by auto zone tomorrow.
Eric
Old May 25, 2004 | 09:35 PM
Smkndzl's Avatar
We get some Dodges in asking what could be wrong with engine not starting when hot , after the sticker shock of how much a pump and labor is , they will be out there trying to start the truck , I usually go out there with glass of cold water and pour it on the pump and it will start , but for sure the pump still needs replacing .
Old May 25, 2004 | 11:26 PM
Well; I was hoping it wouldnt be the pump, but i guess it must be. Any idea where the cheapest rebuilt pump could be bought at on the net that is a reliable place to do buisness with? Just wondering in case we cant find anywhere local. So, does it not hurt to pour water on the pump? Thanks for the help.
Eric
Old May 25, 2004 | 11:58 PM
Haulin_in_Dixie's Avatar
Originally posted by Happy
I'm having the same problem starting after it is warm. First start of the day ok or if off for 4 or more hours.
About a year ago my lift pump went bad so I replaced it. Then shortly after the injection pump went bad and replaced it too. Two months ago I put the FASS System on and it seems hard to start after warm. Could this harm the injection pump?
Try something Happy, after turning on the key, wait a few seconds before starting. Could be too much fuel pressure at start depending on how the FASS is set up.
Old May 27, 2004 | 03:08 PM
DRESSER DAVE's Avatar
I just bought a inj pump from a company in Detroit,Superior Turbo and Injection,I paid 1050.00 plus 500.00 core deposit.Warrenty is 1 year,unlimited miles.Phone # is 800-525-0164,contact person Bill,I called around abunch of shops,he was the cheapest and well refered.
Old May 27, 2004 | 09:45 PM
Thanks for the help Dresser Dave. I will let my uncle know about the shop, and see what he wants to do. We havent had any codes checked yet, but were pretty sure its the inj. pump. Thanks for the help.
Eric
Old May 1, 2005 | 09:59 PM
blackdog1's Avatar
run the truck till it's warm shut truck off run cold water over vp pump if it starts right away put new pump in..fast way to see if pump went..
Old May 4, 2005 | 09:25 PM
JAFAW's Avatar
Try Diesel Injection Service Louisville,Ky (502)361-1181
InjuredOften
Jan 21, 2011 05:41 PM
Seeyaby
Dec 12, 2010 08:06 AM
MikeyT
Jun 8, 2006 12:42 PM
RamHunter01
Feb 2, 2004 08:51 PM
MARKY MARK
Jan 16, 2004 03:49 PM
