Anyway to tell if IP has been replaced?
Old Nov 30, 2006 | 12:12 AM
lovinCTD59's Avatar
I was just wondering if there is anyway to tell if the injection pump has been replaced in my truck yet?
Old Nov 30, 2006 | 06:08 AM
crobtex's Avatar
A lot of the rebuilt VP's will be black instead of silver.
Old Nov 30, 2006 | 06:14 AM
graphitecumnz's Avatar
not fool proof, but there is a factory installed void sticker on the electronic connection on the back of the VP-44...
Old Nov 30, 2006 | 08:08 AM
Copenhagenjunkie's Avatar
Could possibly be tan if it is a cummins recon. Mine is anyway.
Old Nov 30, 2006 | 08:12 AM
JD730's Avatar
Definitely not a sure fire way, but look at the injection line nuts, look at the nuts holding the pump to the case. See if you see any evidence of wrench or tool marks on them.
Old Dec 2, 2006 | 10:35 AM
D2 Cat's Avatar
On rebuilt pumps you'll usually find a red or orange substance on the heads of the screws holding it together. When the coating is cracked or missing it usually indicates it's been tampered with. There is usually a sticker from the remanufactor attached also.
Old Dec 2, 2006 | 10:48 PM
cumminspower79's Avatar
I agree on the black\silver issue, my original was silver, but when I got it back from the dealer it was black.
Old Dec 2, 2006 | 10:58 PM
JAX's Avatar
JAX
If you have a hookup at a Dodge dealer, any Dodge dealership will work, they can run a check throughout all of the dealerships in the country to see what work has been done on that truck by the dealer. They run a search with the vin number through the database. It's not a 100% foolproof, because not all IP's are replaced at the dealer, but I think most probably are and if so, it would tell for sure. The general public doesn't know too much about this search and Dodge likes to keep it hush hush. But if you have a friend, they can run it for you and tell you. Chances are they won't let you have or even see the printout, but they should tell you either way. HTH
Old Dec 3, 2006 | 06:43 PM
Sixpack's Avatar
I took my vin # to the dealer and got not only a copy of the build sheet but also a copy of the service history with no hassle at all. Worth a try!
Old Dec 3, 2006 | 07:31 PM
1-5-3-6-2-4's Avatar
Mine says reman right on the top of it...........which its giving me a P0216 anyways
Ahousaht Diesel
May 25, 2007 09:45 AM
tony597fitter
Dec 17, 2006 06:30 PM
rodda
Oct 25, 2006 05:43 PM
scarecrow
18
Jun 19, 2005 11:30 AM
mr T
Nov 22, 2004 07:58 AM
