KDP - How do you know if it has been replaced?
Old May 24, 2007 | 07:59 AM
Ahousaht Diesel's Avatar
I have bought this 2500 and have received several replys from the DTR forum about getting the KDP fixed. Is there anyway to know if the KDP has already been fixed? If not, what other work would be good to do once the cover is off?
Old May 24, 2007 | 09:09 AM
Dr. Evil's Avatar
If it has been tabbed (the most common fix) you wont know until you get the timing cover off.
Heres some links for you showing both methods of repair:
http://www.dodgeram.org/tech/dsl/Dowel_Pin/tab.htm
http://www.dodgeram.org/tech/dsl/Dowel_Pin/bolt.htm
Also, more general CTD info for you here:
http://www.dodgeram.org/tech/dsl/maint/2nd_Gen-12v.htm
There are several more bolts (6 or 8 I believe), that should be secured with red or green Loctite.
Old May 24, 2007 | 10:56 AM
ratsun's Avatar
The Dr. is correct however there are also many shops that use a jig and drill a hole in the cover, then insert a screw that will hold the pin in place so you would be able to see that.
Old May 24, 2007 | 12:54 PM
Dr. Evil's Avatar
This can be seen in the third link I posted. Problem is that they dont show what it looks like when its done. Never seen one but I assume it just looks like a screw/bolt on the timing case.
Old May 24, 2007 | 06:38 PM
infidel's Avatar
The jig bolt head is behind the fan pulley and recessed. Don't think you can see it without removing the pulley, even with a mirror.
Old May 24, 2007 | 06:45 PM
Dr. Evil's Avatar
Sooo, with that excellent bit of info....either way you have to pull that timing cover off. Thanks Bill.
Old May 24, 2007 | 08:45 PM
DRam11's Avatar
The drill jig method interests me. Where does one get one, or is it a 'large shop' only tool?
Old May 24, 2007 | 10:10 PM
DRD's Avatar
DRD
When I did mine I just pulled the cover and tabbed it. The jig seemed like a lot of work and trouble to track one down.
Old May 25, 2007 | 09:45 AM
infidel's Avatar
You can buy a jig from Harold at rvhvnfn@juno.com or 208 850-8749
Last I checked they were around $30.
Smokin96_12v
Oct 12, 2009 07:39 AM
tony597fitter
Dec 17, 2006 06:30 PM
lovinCTD59
Dec 3, 2006 07:31 PM
rodda
Oct 25, 2006 05:43 PM
Tommy93w350
Sep 20, 2006 10:47 PM
