adjusting valves...where is BDC
Old May 16, 2006 | 02:47 PM
Big Deezul's Avatar
I found TDC and adjusted those valves...where is the BDC mark?
Old May 16, 2006 | 04:27 PM
Cmonroe's Avatar
Your crank moves at a 2 to 1 ratio with the valvetrain. Your TDC compression is your first adjustment, then rotate your crank 360 again to TDC and you will have TDC exhaust.
Old May 16, 2006 | 06:21 PM
piperca's Avatar
You adjust 1l, 1E, 2l, 3E, 4l, and 5E at TDC, which is when the line on the timing gear (fuel pump) is at the top (12 o'clock) position, then you rotate 180* so the line on the timing gear is at the bottom (6 o'clock) position and adjust 2E, 3l, 4E, 5l, 6l, and 6E.
If you use Cmonroe's method, you'll need to mark the harmonic balancer.
Old May 16, 2006 | 08:10 PM
Big Deezul's Avatar
is there another mark inside that I need to line the timing mark up with?
Old May 16, 2006 | 09:31 PM
piperca's Avatar
At the top of the opening where the crankcase vent tube is removed there is a TDC mark. When you rotate the engine, just place the line 180* from the first. If you have concern with judging the 6 o'clock position, place a mark on the harmonic balancer and rotate the engine until the mark returns to its original position. Check the line on the timing gear and it should be at the 6 o'clock position.
Hope this helps!
Old May 17, 2006 | 07:00 AM
Big Deezul's Avatar
indeed
thank you
Old May 17, 2006 | 10:51 AM
Big Deezul's Avatar
I just finished mine up...is it normal to see a drop in EGT...some of mine were out a good bit. Truck runs good. I wish I did it a long time ago.
Thanks for the tips piperca I marked the balancer with a dot of red touch up paint where the serp belt comes straight down on the right side and then spun it untill that came back up. I checked with the mirror and it was dead on 6 o'clock and finished up the other valves
Old May 17, 2006 | 04:02 PM
piperca's Avatar
Glad I could be of assistance!
Old May 17, 2006 | 04:38 PM
storx's Avatar
can anyone drop me a link to a more detailed guide for adjusting the valves....??? also whats the trick with taking the valve cover off... i spent over 30 mins trying to get it to come off and couldnt for the life of me get it unwedges from there...
Old May 17, 2006 | 05:00 PM
Big Deezul's Avatar
it doesnt get more detailed then the guide in the tech fact section. The trick to the valve cover is removing the bolts before you take it off. Move the back end toward the left side of the truck (your right) and rotate it as you move it over then pull it straight out.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old May 19, 2006 | 08:38 AM
mini14's Avatar
it sounds confusing...take pump/breather cover off, rotate till mark is at 12.when at 12 mark your harmonic balancer with a sharpie. do your first set of valves, then rotate the balancer 1 complete revolution till your mark is in the same spot.then do you second set of valves....just remember too tight is ng.
Old May 19, 2006 | 09:08 AM
P Kennedy's Avatar
OR with a long handle ratchet and socket on the alternator pulley bolt to turn the engine- when intake just closes set exhaust/ when exhaust just closes set intake for every cylinder. Takes a little longer but is never "wrong" on any 4 stroke engine and no timing marks or procedure otherwise needed and easy to remember. I prefer to start at the back (#6)as it causes the most stress and end with the front (#1), last time installed new injectors and set valves with the kid's help(wrench puller/engine turner) in 55 minutes including the valve cover part. PK
Old May 19, 2006 | 11:40 AM
storx's Avatar
thanks for the link.. i was trying to find a good link for info but all i could find was 12v sites and listings. but when you rotate the engine backwards with the alt nut you do BDC or TDC first? and then you still do 1 turn to get the other adjustments?
Old May 19, 2006 | 01:37 PM
piperca's Avatar
Yes, TDC first, then rotate the timing gear so the mark is in the 6 o'clock position and set the rest.
skymiles
Feb 28, 2007 03:52 PM
robox
Aug 16, 2005 07:27 PM
CrewCabCummins
Jan 3, 2005 04:29 PM
Denis
Apr 19, 2004 12:32 PM
Puke
Jun 23, 2003 01:06 PM
