AC Delco oil filters
Delco makes a good filter. General consensus is the Fleetguard Stratopore is best, after that it's pretty much a tie between several respectable filter makes. Delco being one.
the last time I saw a Delco filter cut in half, it had less filter media inside compared to Fram and Wix. That was several years ago, maybe they improved since then. But if DC says they're OK, then I guess they must be
I always use the oil filter that came with the enigne from the factory. Pressure and flow rates can differ between them. I'm a firm believer that using the factory specd one reduces oil leaks down the road. I have too much money in my rig to put on a cheap oil filter.
Just my 1.5 cents
Just my 1.5 cents
staarma
28
05-01-2008 11:10 AM
fitzydog
10-12-2007 10:23 AM
