Steering Box
Old Oct 26, 2005 | 03:04 PM
cjthor's Avatar
Steering Box
Should there be any play in the shaft the goes into the steering box. If I grab the steering shaft, I can move it a little. I am trying to get to the bottom of the floating feeling I sometimes have in the front end. I have replaced the usual suspected parts. As of the begining of the summer the ball joints were fine.
Cjthor
01 Ext Cab Long Box 4x4 H.O 6spd. no mods
Old Oct 26, 2005 | 04:58 PM
pind's Avatar
www.soldisteel.biz
Check out the steering stabilizer. I have put them on my own truck, as well as many customer's trucks, does wonders for the steering, and cheaper than a steering box.
Old Oct 27, 2005 | 01:30 PM
Cowhand's Avatar
But it won't do much for you if the steering box is already shot....been there, done that. You can try the bearing preload adjustment, instructions are over on dodgeram.org. I did it until I reached the point of diminishing returns and replaced the box. PSC makes a nice box for around $300.....
Old Oct 27, 2005 | 08:52 PM
electrifried's Avatar
I would recomend to NOT get a NAPA box. I need the second one replaced in three months. What a pain.....
Old Oct 28, 2005 | 01:37 PM
cjthor's Avatar
Any other recomendations. AGR with Borgeson shaft?
Old Oct 28, 2005 | 01:38 PM
RowJ's Avatar
Agree with Cowhand. PSC is excellent...and a fair price.
http://www.pscpowersteer.com/
That's if it's beyond the point where the DSS will solve your problem.
COWHAND...will the PSC box hold by itself....or does it still need the DSS for lasting - long term?
RJ
Old Oct 28, 2005 | 01:44 PM
cjthor's Avatar
Maybe if I would read more carefully I would have seen that recomendation.
What about the shaft?
Cylinder assist or varialble ratio?
Old Oct 28, 2005 | 02:00 PM
cjthor's Avatar
Is the Steering Gear Brace that is on the PSC website the same or different the DSS from SolidSteel?
Old Oct 28, 2005 | 03:18 PM
CTD NUT's Avatar
This steering brace is a DSS - the same unit that DSS offers. The PSC box has no extra bearing support on the pitman shaft compared to the stock box so it would benefit from a DSS.
Old Oct 28, 2005 | 09:30 PM
jdeereboy's Avatar
I do not understand how the PSC box can be "variable ratio". What is the ratio in the stock box? I want to get a box with a quicker ratio as my truck seems to understeer.
Old Oct 31, 2005 | 06:00 AM
CTD NUT's Avatar
Most all steering Saginaw steering boxes are variable ratio......fixed ratio boxes are a thing of the past. I have no idea if PCS offers different ratios.
Old Oct 31, 2005 | 02:08 PM
cjthor's Avatar
To anyone intrested:
I spoke with someone at PCS today, his opinion was to use the DSS kit if the steering box was not leaking.
Old Nov 2, 2005 | 08:48 AM
DaNuGuy's Avatar
I got my DSS from PSC as well as a hydro assist kit for my jeep. They make good stuff and the customer service can't be beat.
Old Nov 2, 2005 | 09:14 AM
cjthor's Avatar
Should I have the steering box adjusted before I put the kit on? I think it would make sense. I had a buddy of mine driving the truck this weekend. He almost put it in the buck brush.
The clyinder assist box allows the more things to be hooked up to it versus the variable ratio box.
Old Nov 2, 2005 | 09:22 AM
BlueRam01's Avatar
Another vote for PCS with a DSS and Borgeson shaft. Have that setup on my 1500 after the original box puked the pitman seal. Unfortunately the Borgeson shaft is rusting but the annoying clunk is gone.
