47re to NV4500 swap
Old Jun 4, 2009 | 05:37 AM
laurel2000's Avatar
47re to NV4500 swap
Hi folks. I recently converted my 2000 over to Manual using the nv4500 and everything came out excelent with one exception, the ECM or PCM still thinks the truck has an automatic and is throwing every code in the book. If I clear the codes, they come back after a while. Is there a way I can clear thease codes with a few jumpers or remove a few wires or do I have to change the PCM and wiring harness?? Any help is always apreciated. Thanks.
Old Jun 4, 2009 | 12:56 PM
tmills's Avatar
You will need to jump the connectors and make the PCM think it is in neutral. I saw how to do this somewhere, but I can't remember which forum it is on.
Good job on the swap if you have gotten this far. The hard part is definatly over.
Old Jun 4, 2009 | 10:14 PM
laurel2000's Avatar
It starts and runs. It just throws codes. The nuetral switch is jumped allong with the clutch pedal swich.
Old Jun 5, 2009 | 08:50 AM
Southern Pride's Avatar
laurel, does your truck only rev to 2000rpms when first cranked up, then after you get over 20mph, it will rev till redline? mine does that. dodge and a few other mechanics told me that if i switched out the pcm it would fix that. i havent had any codes thrown yet though.
Old Jun 5, 2009 | 09:11 AM
Beast2B's Avatar
shoot off as mesage to Bob Wagner. I remember seeing posts where he has helped folks with ECM issues in a tranny swap. his website is smartypower.com for other contact
Old Jun 5, 2009 | 09:21 AM
BarryG's Avatar
I am considering doing the swap as well. However in regards to your ecm/pcm question if a new one is needed try www.autocomputerexchange.com. They have fairly reasonable prices on ecms and pcms(at least compared to dealer prices).
Old Jun 5, 2009 | 03:18 PM
laurel2000's Avatar
Southern Pride. Im not to sure what it revs up to? But it shift fine and works normally. I probably need to change out the ECM. I think I will give Bob Wagner a buzz. Thanks.
Dieselnick
Mar 28, 2015 12:11 PM
bwareofblksmoke
Mar 30, 2011 10:52 PM
TNutcher
Apr 25, 2009 07:14 PM
dieselfuelonly
NCDTR #18
Aug 11, 2008 06:22 AM
Diver_Dan
0
Jun 9, 2008 08:08 AM
