216 code
Old Mar 30, 2010 | 07:44 PM
whitetop's Avatar
ok i will try to after i unplug it do i need to connect any of the wires from the edge some where else or do they just unplug and thank you for your help
Old Mar 30, 2010 | 07:50 PM
Copenhagenjunkie's Avatar
It been a while since I chucked my ez in the trash......... here is the manual.
http://www.edgeproducts.com/product_...manual-153.pdf
Old Mar 30, 2010 | 11:28 PM
totalloser's Avatar
??? How could a timing box cause this? It doesn't even tap the pump. Saying that the problem simply is the box is a bit quick on the draw, but I guess it IS pretty easy to unplug.
The way I understand it, the EZ fools the boost sensor, increases injection timing, and tricks the boost sensor to allow low boost fueling to get the turbo spooled up. I don't see how any of these features could possibly cause the problems listed.
With dead pedal in addition to the first post from the OP, it does start sounding like a bad VP, though.
Old Mar 31, 2010 | 03:44 AM
whitetop's Avatar
well i unplugged edge and took a test ride and seem to have the same problem i will reset and pull cades again at work it is not looking good for the home team but im not giving up yet thanks for any help and for the help so far
Old Mar 31, 2010 | 05:18 AM
wurkenman's Avatar
Mine did the same as your truck before the pump went. I was half way between Minnesota and Colorado. Please listen and replace your pump. It will go completely at the worst time. Did you read my second sentence?
Old Mar 31, 2010 | 05:40 AM
Experience.
Old Apr 1, 2010 | 04:00 AM
whitetop's Avatar
thats what im thinking also going with a new fass thanks that would be my luck to
Old Apr 1, 2010 | 08:30 AM
Well, I was hoping it was the ez.
Old Apr 2, 2010 | 05:21 AM
whitetop's Avatar
i was also hoping it was the e-z thanks for the help
Old Apr 6, 2010 | 04:14 AM
whitetop's Avatar
well bit the bullet and ordered the fass 95gph 150 series and vp44 from MWFI was told on the phone that 150gph would conflict with stock engine and fuel module causing surgeing and other issues by ruturning to much fuel anyone running the 150gph on stock engine
rickrok
Jul 30, 2009 04:08 PM
2500Ram
May 14, 2008 11:26 PM
cuda72
May 28, 2007 10:43 PM
Chrisf
13
Jun 20, 2003 08:48 AM
