216 code
Old Mar 29, 2010 | 05:30 PM
whitetop's Avatar
216 code
ok i have spent a 100 hours or so its seems like all over the net trying to figure out what my problem is 216 code of death i reset the code it returns but could this be caused by somthing else (fuel pressure..) and what should i check before i order a new vp-44 and fass i have a 1999 3500 5.9CTD love it 78000 miles rough start after warmed up and idle up and down 200-300 rpm and cuts off some times sorry for the long post thanks to all of you for your help
Old Mar 29, 2010 | 05:37 PM
Dr. Evil's Avatar
If your resetting it and it keeps coming back - it sounds very much like its VP-44 time. Dont forget to install a fuel pressure guage so you can keep na eye on your fuel pressure and save your next VP-44.
You could install a fuel pressure guage now - but its likely too late for that.
Wish I had better news for you.
Old Mar 29, 2010 | 05:44 PM
whitetop's Avatar
i wish the news was better to i forgot to mention i do have a fuel guage my pressure is 13 psi. idle 8-9 psi. wot is this a good time to check kdp also thanks for your last i guess iwill breake out the plastic
Old Mar 29, 2010 | 08:01 PM
Dr. Evil's Avatar
well, your fuel pressure seems fine.
How often does the code come back?
Old Mar 30, 2010 | 03:01 AM
whitetop's Avatar
the code comes back after 3 or 4 run cycles thanks again for your respnse
Old Mar 30, 2010 | 05:13 AM
wurkenman's Avatar
P0216 is injector circuit malfunction. There is NO turning back the clock. You need a new VP44. This is an electronic failure, not mechanical. You can get by for a while with the dead pedal, but sooner or later you WILL be stranded somewhere.
Old Mar 30, 2010 | 06:00 AM
Clunk's Avatar
P0216 Fuel Injection Pump Timing Failure.
High fuel supply restriction, low fuel pressure or possible wrong or incorrectly installed pump keyway.
Old Mar 30, 2010 | 06:01 AM
Copenhagenjunkie's Avatar
Wow, some low miles for the year. Sorry, you need a Vp-44. The electronics are much better now. I am close to 300k on my 2nd Vp.
Old Mar 30, 2010 | 08:49 AM
cmmins's Avatar
I have read on CF that one owner had the 216 code, and he replaced the IAT sensor, he reported it fixed his problem, i am not saying you don't need a VP but it is only about $50 for a shot in the dark.
Old Mar 30, 2010 | 04:38 PM
whitetop's Avatar
sounds like a shot in the dark that i will look into does anyony know if i can clean or test this and please tell me where it is this i my first diesel thanks in advance for all the great help this site is a life saver
Old Mar 30, 2010 | 05:52 PM
totalloser's Avatar
It's hard for me to immagine the AIT throwing a 216, but according to Blue Chip (who's pump I'd personally buy) the 216 is not the code of death it's claimed to be. I don't know why they say that and what the 216 can otherwise be, but were it me, I'd do some more homework.
Check all the easy stuff, though. Some attention to the plugs can't hurt. Fuel filter is cheap, and you probably have two-OE and the Airdog.
A sticky actuator, or sticky injector could probably cause those symptoms. Fuel system cleaner is a long shot, but a very cheap one. Getting any white smoke?
Old Mar 30, 2010 | 06:14 PM
whitetop's Avatar
yes i do have dead pedel but only notice when the engine is cold and trying to take (most times not all the time) off no matter where you hold or push pedel for aprox. 15-25 seconds on cold start i have white smoke which is getting worse after engine is at run temp. i have up and down rpm and engine cuts off when put in foward or rev.until you press fuel pedal slightly as you put in gear fuel milage is around 12-13.5 mpg highway i have 410 gears and it is 4wd sorry for long post just trying to make the wise decision and thanks again for all the good help
Old Mar 30, 2010 | 07:26 PM
Do you have a performance box installed?
Old Mar 30, 2010 | 07:33 PM
whitetop's Avatar
yes i do it is a edge not sure which one its under the hood and is a small box aprox 1in. thick and 4in.long and 3 pins i tried all and found the problem is the same
Old Mar 30, 2010 | 07:39 PM
So you have an edge ez, should say on it somewhere. REMOVE IT. It's very likely that's your problem.
