wont start- no juice to anything ?
Old Jan 18, 2007 | 11:08 AM
crossy's Avatar
1991 N/I, trucks been sitting out and it has nothing but the door buzzer. battery shows full juice. i replaced the start/run relay already, any ideas. thanx , crossy
Old Jan 18, 2007 | 11:27 AM
Micaiahfied's Avatar
check the wire to the shut down solenoid make sure it didn't get bumped off.
Old Jan 18, 2007 | 12:40 PM
crossy's Avatar
OK good thing i saved all those pics of the componets that Wanna labeled for the guy a weekago, LOL , i'll find it. thanx , crossy
Old Jan 18, 2007 | 12:48 PM
Chrisreyn's Avatar
Crossy, you do know there is a clutch interlock switch that can go bad right?
you'll havea'dead key"with no power if you turn the key while the clutch pedal is out.It hasto be depressed. You can jump this switch to test it.
Old Jan 18, 2007 | 12:55 PM
crossy's Avatar
thats just for start mode right? I have no power to headlights, warning lights, etc. only the key buzzer works. thanx .
Old Jan 18, 2007 | 01:00 PM
Chrisreyn's Avatar
Oh...Well, then you have a bigger problem! the headllights arentconnectedto teh starter circuit in anyway.....so that would indicate your problem is somewhere back in teh cirucuits where allof these come together...like at the battery or immediate wiring from it.
Fuse block, fusiblelinks under teh hood ,main grounds.......
Old Jan 18, 2007 | 02:13 PM
jiMMyCTD's Avatar
the slightest bit of corosion or lose battery cable will cause similar issues. otherwise eeekkkkkkk.
Old Jan 19, 2007 | 07:31 AM
Chrisreyn's Avatar
any update on this Cross?
Old Jan 19, 2007 | 07:50 AM
crossy's Avatar
nah, I'm a shift worker and I don't get home till 8PM and last night I had to pull a cab off a truck frame when I got home . I thought i was done doing that stupid stuff but i never learn plus i keep running out of mad money. I Also thought I wasn't buying anymore trucks until I found a 92 W250 CTD on ebay close by???? and I even had enough in my paypal for the big deposit he wanted. to say that it is rough might be a bit of an understatement. . good news is I no longer have to worry about dividing my money between food, clothes or heating oil this month.I spent it all.
Oh, the wife?
my son? he's wired about this new heap.
rustydeeretech
Jun 16, 2010 09:41 AM
Stroked-Z
Oct 4, 2008 11:28 AM
qcstunter
Jan 9, 2007 04:10 PM
VikingDiesel
Nov 15, 2006 12:24 AM
