Wiring Harness?
Wiring Harness?
Looking to re wire my truck. Last owner took the truck to a shop that messed everything up Would be better off just re wiring the whole truck or finding all the shorts myself and fixing just those? ideas?
I was driving home today on the freeway when my cruise kicked off, speedo went to zero, radio went off and no turn signals. I knew it must have poped the fuse I replaced the crispy fusible link with, and it kept poping then as fast as I replaced them. Some hot wire is touching ground somethere. Ticks me off.
I got a headlight problem i have to turn on the brights then turn them off to get regular head lights, my water in fuel, wait to start lights come on when i turn on the a/c or heater which both dont work. my speedo works on and off depending on what bump i hit and how fast im going.OD doesnt work. and there are about 7 to 8 wires connected to the positive post on my battery there is a lot
Sounds like your ignition switch is having issues (among other things).
These trucks have so much battery and alternator capacity that there is little room for error on the wiring. If we ran at 48 volts the wires would only need to be 1/4th as thick as they are now!
Good luck, I feel your pain.
Buzzers all work and she fires right up. im thinkings about doing a thicker heavier cuty wire when i re wire the truck
Good luck to you as well!
Good tip of advice if you're going to grab a spool and go, Label your wires somehow so you know what's what if you have to troubleshoot....makes life a whole lot easier. I install 2-way radios and EMS Lights/Sirens/etc and it helps a lot
I'm going to end up having to do a bit of wiring as well, going to try and relocate /replace that darn fuse panel with something i found from cooper bussman
http://connectorconcepts.com/product...files/RTMR.pdf
It's just a mini fuse panel but it is 4.5" X 3.5", holds 20 fuses and has a split bus bar which means you can have one side 12v hot all the time and 12v off the ignition.
Now i just need time to do it two little kids and a wife always keep me busy somehow
a buddy that fixes our firetrucks radio gave me this site for electrical stuff and it has been pretty helpful.
the12volt.com
might have some info that will help ya.
the12volt.com
Here it is installed. The large stud to the right of it is a ground. The Maxi fuse (60 amp) feeds the trailer relays. The other fuse feeds the transmission cooler.
And here's the trailer "harness" I removed from the truck before I rewired it.
wyododge
01-13-2009 02:25 AM
Hummin Cummins
03-24-2003 07:41 AM
