will lift look dumb on 2wd?
Old Jul 21, 2005 | 06:48 PM
Micaiahfied's Avatar
i am looking to level the truck out with springs and then add another 2" front and back. i don't want to put a block in the spring but if i can find a ring to go under the spring i would like to do that. i will be adding a powr-lok and proabably a hitch mountable winch i would like to make up for the fact that i am only 2wd. any input is appreciated... thanks!
Old Jul 21, 2005 | 07:24 PM
timb's Avatar
I dont know who was making them, but a company makes lift kits for two wheel drive trucks. and I think that a lifted 2 wheeler looks .
Old Jul 21, 2005 | 07:43 PM
has anyone used this product?
http://www.truckn-store.com/product....t.asp&ID=85875
and why does it need a new upper control arm?
Old Jul 21, 2005 | 08:02 PM
12vordie's Avatar
After you raise the front of an independant suspension vehicle past a certain point the top of the tire will lean in and can not be adjusted out far enough to straighten it out therefore you need a longer upper control arm.
Old Jul 21, 2005 | 08:08 PM
i've heard of guys putting a 2 inch lift along with 7226s... any of you guy out there have a problem getting it alligned?
Old Jul 21, 2005 | 08:21 PM
also.... does anyone know if this product will work on my truck...
http://www.truckn-store.com/product....t.asp&ID=79031
3rd from the bottom
Old Jul 22, 2005 | 04:08 PM
My previous truck ('85 gasser D250) had been equipped with some springs off a locomotive (probably the 7226 springs) by a PO. It sat with the control arms not quite touching the upper bumpstops, about 4" of lift. It could not be aligned properly due to excess negative camber. And it rode like crap because there was almost no down travel in the front suspension. That and the 9 leaf packs in the back made it a "beater" in more ways than one.
Old Jul 22, 2005 | 04:27 PM
P.J's Avatar
P.J
Yes
Old Jul 22, 2005 | 05:16 PM
signature600's Avatar
Here!!
Not the same body style, but it's what you wanted right??
[IMG][/IMG]
I've got 1.75" up front and the same in the back...sits level except when I have the trailer on, then it's just high enough in the front if you stand back about 100ft you can tell.
The thing with a lift on a 2wd is you can't go a whole lot taller than what I've got, or bad things happen like has already been mentioned. Another thing is finding shocks that will fit!
HTH,
Chris
Common
Jul 12, 2007 12:39 AM
bsj04
Jun 30, 2007 03:31 AM
Dodge@KY1997
21
Feb 4, 2007 08:00 PM
NCTURBOS
May 27, 2006 12:29 AM
