why so much negative wheel camber
Old Sep 24, 2008 | 10:28 PM
STACKED's Avatar
Whats up with he camber on my 91.5 w250 4x4? we just did bearings and races to try to get the tire to stand up straight, the king pins seem fine no movement of the tire in or out. are the king pins adjustable?
Old Sep 24, 2008 | 11:28 PM
Philip's Avatar
King pins are not adjustable. There is a camber correction kit on the market. It is listed in the stickies.
A bent axle housing can give you lots of chamber also.
Old Sep 25, 2008 | 06:44 AM
Mclair's Avatar
I can't find the camber corection kit any where in the sticky is there a link someone could post that takes you to it?
Old Sep 25, 2008 | 06:23 PM
u.s mma's Avatar
did you do the white bushing and new spring on top of the kingpin?
Old Sep 25, 2008 | 10:07 PM
STACKED's Avatar
i dont think the tube is bent is exactly the same on both sides. chevy 60s are not like this.
Old Sep 25, 2008 | 11:19 PM
Philip's Avatar
My bent front 61 wears both front tires the same amount.
The chamber correction kit is Moog K992
I hope this link works. It shows a pic of it.
http://www.rockauto.com/dbphp/prt,11,K992
Hea mister mod. Add this part to the stickies under the suspension section. I didn't find it listed in there.
Old Sep 26, 2008 | 05:14 PM
STACKED's Avatar
104$ per side wow i might leave it alone for a while
Old Sep 26, 2008 | 06:04 PM
dodgetrucker75's Avatar
i have found that even though the king pins feel tight when tring to move by hand, they can be worn and even broke, but you will wont beable to move it by hand, maby just take a real close look at your upper king pins, if you havent already done so.
Old Sep 26, 2008 | 06:28 PM
STACKED's Avatar
i might have to check that out. would i have to tear the hub back down and off just to check?
Old Sep 26, 2008 | 11:12 PM
u.s mma's Avatar
No, I dont' think so, pop off the pitman arm and pull the nuts off the studs. the spring, retainer and bushing are right there. dana part#s are 37300 for the spring, 41886 for the bushing. I think the retainer came in the lower bearing kit. I could of reused my old one.The spring was 6.98 a side and the bushing was 3.12.
Old Jan 6, 2009 | 10:22 PM
Paul S.'s Avatar
Would you guys ever recommend getting a kit like this (http://www.pirate4x4.com/tech/billav...pin/index.html) or should one just get the individual parts? It looks like there may be some redundant parts between the camber correction and the rebuild kit.
Does the camber correction effect the handling much? My tires have always worn more on the inside and have had similar thoughts... Recently I have also been getting the wandering feel in the wheel...
Thoughts...
Old Jan 6, 2009 | 11:41 PM
Philip's Avatar
The chamber correction kit is adjustable. Just throw the truck on a front end rack and have them set the chamber.
I have a kit on my truck.
Buy the kit. If your going to do the top side of the knuckle. Do the bottom to. You probably won't beleave how bad of shape that bottom bearing is after 15+ years of road use.
O5DodgeRam5.9
0
Jun 30, 2010 12:37 PM
sgrooms
21
Apr 8, 2008 11:17 AM
piperca
Mar 8, 2008 12:34 PM
w4xtc
Feb 18, 2004 08:55 PM
dma251
Jun 19, 2003 04:17 AM
