Negative camber on a 2WD.
Old Mar 7, 2008 | 08:27 PM
piperca's Avatar
A couple of years ago, I replaced the springs in my front end with 2" over stock. At that time, I replaced all of the ball joints with greasable Spicer joints. I have been experiencing rubbing from the tires in the wheel well liners and was forced to remove the driver's side while I looked for a solution. Recently, I've noticed the front driver's side wheel is showing visible negative camber. The passenger's side wheel is now starting to rub, too. What could be causing this? I have her scheduled for an alignment tomorrow morning, but what should I expect to hear from the alignment guy? Bad wheel bearings or what?
Old Mar 7, 2008 | 09:08 PM
Number47's Avatar
wheel bearings or upper ball joints
Old Mar 8, 2008 | 12:34 PM
piperca's Avatar
Just got back from the alignment shop. The front end is fine, it's the spring lift that is the problem. I am maxed out on the adjustment and still have 1/4 degree on the right and 3/4 of a degree on the left, negative camber. This truck will never be right, unless I put it back to stock. There are no aftermarket control arms or spindles to do this right, so she's going to have to go!
jeff355
Sep 30, 2009 09:39 PM
STACKED
Jan 6, 2009 11:41 PM
PapaPerk
23
Jan 1, 2005 07:33 AM
w4xtc
Feb 18, 2004 08:55 PM
