Who's going for the Record??
Im going for the record also. Im 19 years old and live near san antonio texas, I have a 91 single cab long bed. The motor is out of a 91 with non intercooled pistons machined .060 for valve clearance, Im running hamilton cam pushrods and valve spring, The head has the log machined off ported and polished and stuffed with bigger valves, engineered diesel big single, built 47re with manual valve body, and a 4 link. Plus some other goodies. If my boss will keep giving us 65 hour work weeks ill be there soon.
I talked to KTA a while back and he said there are like 20 trucks around his area running around with the 14mm, making about 400 hp. Some even with stock turbos. If you keep the pumps turned down for extended driving, and limit your rpm to about 3500, I think that helps em a lot.
I think it goes something like this:
1.STOMP 708-14mm nitrous
1a.STOMP 680-14mm water/meth
2.KTA ~650-14mm fuel
3.Tom Collins 587 12mm water/meth and nitrous
4.Jayers 575-14mm fuel
5.Bill Gilbert 556-fuel
