White smoke.
White smoke.
Ok,I'm still having probablems with the starting and white smoke.now when I start it I get a cloud of white smoke and even at idle there is white smoke coming out of the exhaust.I tried presserizing the tank didnt see any leaks.The injecter I thought had oil around it,I pulled and cleaned and retourqued.Then bled it for air..So what is happening?
the probalem with starting is,I turn it over and it's like starting a powerstroke it doesnt go doenst go I roll the key back, then try again turns over then starts, sounds like it has a miss, has a big cloud of white smoke then clears up.
Pull the cap off the radiator and see if there is any water in there. If not you may have a head gasket problem. Hard starting, white smoke and lack of coolentin the radiator could be an indication of this.
Did you say its gotten worse? I'm not saying you're having the same prob. I did for sure just telling you what I went through. When my first pump started to go it would not start right off, then it would take just a touch longer but would still start every time and had a touch of grey/white smoke, then it got to where it wouldn't start without ether, then only when good and cool when I was lucky, then no start at all. If it just keeps getting worse and especially hard to start when hot then its bout shot. If you have trouble with hot/operating temp. starts, run water over the back of the pump for a min. then if it lights right off you know your pump aint got much time. I could be wrong. Just sounds like what I went through. Best of luck!
Ok I popped the top off the raditor it was full of coolant.Open the bleed screw before starting and then it started on the first try.So what else can I do to check for air getting in?
i have seen a lot of problems with the plastic fuel lines from the tank to the lift pump causing starting problems, maby just try replacing with rubber hose, or i like to use th 3/8 steel brake line you can find at napa. i have delt with three pickups my self and reaplacing thoes lines cured the problem,
recone5
11-05-2008 10:26 AM
RJOS
16
09-03-2007 09:19 PM
BuildingBoost
03-25-2007 07:46 PM
BlackSheep5
11-27-2006 07:52 PM
