White smoke...then black smoke.
Old Nov 5, 2008 | 09:45 AM
recone5's Avatar
This has just happened recently. The truck always blew good black smoke on performance setting. Then one day leaving work, i waited till she got up to temp and got on her. It blew white smoke and continued to do so the rest of the day. The next day it was black again. So it does this every couple of days, under different weather conditions. I replaced the fuel filter, ran a tank of injector cleaner through it. I then took it to the dealer where they ran the injector fail test and ran it around. They say its fine. I have also noticed that since it has started to do this, the get up and go has deteriorated and it does not dump the smoke it used to. Could it be the winter diesel? Is the programmer? Anything would help.
Old Nov 5, 2008 | 09:58 AM
soulezoo's Avatar
DTR 1st Sergeant
Possible small HG failure?
White smoke is either unburned fuel from sticky injector or valve not completely closing; or, steam from coolant escaping into cylinder.
Those are just guesses... hard to troubleshoot from the computer.
Old Nov 5, 2008 | 10:26 AM
recone5's Avatar
If it were a head gasket, would it not do it all the time? It's about to get an oil change so I'll definitely be looking at the old oil.
jlipskoc
Nov 27, 2008 08:41 PM
RJOS
16
Sep 3, 2007 09:19 PM
BuildingBoost
Mar 25, 2007 07:46 PM
BlackSheep5
Nov 27, 2006 07:52 PM
dhe9
Nov 14, 2003 07:31 AM
