What is needed for nv4500 transplant?Who has best Kit/price?
Old Nov 15, 2009 | 07:44 PM
Elohim1's Avatar
I currently have the getrag with the NP205
From my searches it looks like you need a
1)NV4500 of course
2) and an adapter kit from AA to make it mount to the np205.
Is this all ?
Here is a link to a complete kit for about $3k
Is there a better supplier for kit?
http://www.drivetrain.com/parts_cata...4500Conversion
Old Nov 15, 2009 | 09:21 PM
Riflemanusmc's Avatar
Registered user
I don't know what you expect to gain from the swap? Nothing in real world terms....What are you wanting/needing from the swap, if I might ask..
Old Nov 16, 2009 | 04:40 AM
Trebor's Avatar
The 4WD NV4500 mounts directly to the NP205 without any modifications other than removing the rear seal in the NV4500. This seal removal permits the coupler splines run in oil.
I bought a "kit" when I did mine. The transmission rebuilder freighted the transmission and the AA #712584 kit came as third party direct via UPS from Advance Adapters. Five years ago I ended up paying close to an extra $400 by having the trans rebuilder order it for me.
The 4WD kit and the installation instructions:
http://advanceadapters.com/product/3...ne-NV4500.html
Old Nov 16, 2009 | 02:18 PM
NO_SPRK's Avatar
go to car-part.com and look for a adapter plate and bellhousing for a second gen if you dont wanna pay the price for the kit
Old Nov 16, 2009 | 06:56 PM
Elohim1's Avatar
Sounds like a bearing is going out in the getrag. I have heard they are a little tricky to rebuild. This is the only reason. Plus I want a dual disc clutch. I am not sure if one is available for the getrag. Havent looked yet.
Brainstorm me, i want to hear..............
Old Nov 16, 2009 | 07:58 PM
Exekiel69's Avatar
Getrag
-Not hard to rebuild
-Will take fast shifting well
-Noisy (every truck is different)
-Bearing design problems
New Ventura 4500
-Maybe same difficulty level to rebuild
-Will take fast shifts no problem
-5th gear falls
Old Nov 16, 2009 | 08:17 PM
Registered user
There are some older members on here that are DIEHARD getrag people. Bill Gilbert is one of them...Before you make up your mind. Listen to the pro's and con's...
Old Nov 17, 2009 | 02:35 PM
schamran's Avatar
I think their are a lot more upgrades for the 4500. I think there is a kit for 5th gear, and you can get bigger input shafts from Scheids. I think they're 1 1/4" shafts. You do need a modified clutch with that shaft for obvious reasons.
Old Nov 17, 2009 | 03:11 PM
w250_93's Avatar
Ive only got about $1400 in my swap, i found a junk 4500 an rebuilt it then ordered my bellhouseing kit. I think there about the same on the rebuild difficulty, you dont need any speacial tools with either of them if you know a few tricks, but i think the getrag is harder to get the shims right. i ended up paying for one of those manuals from quad 4x4 it was well worth the money. something that i thought was funny was the 4500 doesn't call for preload like the getrag does, they want u to have .002-.006 endplay instead.
Old Nov 19, 2009 | 09:24 PM
cedardiesel's Avatar
Question Since I would like to run the southbend hydraulics because I will be running at least a 3600 plate load dual disk clutch I know I need the second gen bell housing to do that but is there anything else I need to do to adapt the second gen bell housing to factory motor plate? I have heard from several sources that the 1st gen hydros are heavier duty than the 2nd gen factory hydros if this true then would it be ok to run them with that heavy of a clutch?
jmlcolorado
Nov 10, 2012 02:32 PM
primal13
Jun 16, 2009 09:01 PM
getblown5.9
Mar 24, 2005 07:58 AM
IA_James
Mar 3, 2005 04:24 AM
evisr8
Nov 2, 2003 05:39 PM
