What is this foam for?
Old Apr 18, 2016 | 09:18 PM
Diesel_Dawg's Avatar
While I was prepping my cab floor for rust removal I found this piece of foam partially attached to the floor under the seat belt re-tractor.
There is one just like it on the other side, but it is still attached.
Can anyone tell me what it is for and whether it should be replaced?
Thanks,
Chris
Attached Thumbnails What is this foam for?-wp_20160418_18_57_24_rich.jpg   What is this foam for?-wp_20160418_18_57_43_rich.jpg
Old Apr 18, 2016 | 09:28 PM
MrFusion's Avatar
I've recently taken the interiors out of 2 1992 CC trucks in preparation for rust work and didn't see anything like that. The only thing I found behind the seat belt retractor was a flat foam washer that seemed to be an anti rattle device.
That would be my guess is that it is an anti rattle or squeak device.
Old Apr 19, 2016 | 07:35 AM
I just pulled the whole interior out of my reg cab '91.0 and I didn't see that under the seat belts either.
I am guessing the same as MrFusion, with an anti rattle unit.
Old Apr 19, 2016 | 08:05 AM
diesel402004's Avatar
On my cc ive had similiar foam in the same area that appeared to be attached to--or part of--the sealbelt warning buzzer elec. Connection?
Old Apr 19, 2016 | 01:36 PM
Thanks for the responses. Perhaps my truck is special
Just to clarify the location of the foam, here is a pic of where I removed it from.
You can see the Torx bolt that mounts the driver's side seat belt re-tractor in the top left edge of the pic.
Old Apr 19, 2016 | 02:59 PM
mknittle's Avatar
Hey, That's not fair yours is redder than mine.
I think that foam is to dampen vibration noise. but then I get some pretty strange thoughts.
Old Apr 19, 2016 | 08:21 PM
Jim Lane's Avatar
Not sure where it came from, but I have seen adhesive backed foam wrapped around various connectors on my truck especially under the dash, I would assume to suppress rattles.
Jim
Old Apr 21, 2016 | 03:29 PM
Thanks for the replies gents. I guess I wont worry about it unless the rattles start to drive me crazy.
Old Apr 22, 2016 | 06:02 AM
bannerd's Avatar
That area is hard to get a spot welder in and to stop the metal from bending and leaving a hole in the back storage area they used the foam to seal it/keep it together. I saw the same thing in the cab I restored as well as a cab my buddy was restoring. It's impossible to seal that area with a MIG/TIG. The best solution I found was to tack weld to give the metal panel some support and then use high quality seam sealer both sides. Or flip the cab on its side and weld it, seam seal and use good paint to stop the rust. You'll have to cut the cab support though
They came like that from factory, if you have something different I would say someone was there before you.
Old Apr 22, 2016 | 07:43 PM
jerseybud's Avatar
Its hard to describe, but that foam is used as an adhesive between part of the seam where the rocker, cab and inner rocker panel join, in the rear aspect. Its used in that spot, the reinforcement plate for the 6x9 mirrors, and the reinforcement plate for the accelerator pedal on the firewall side.
Old Apr 22, 2016 | 09:43 PM
MrFusion's Avatar
Kind of like old Jeep Cherokee door hinges: glued to the A pillar. Thanks Chrysler!
Old Apr 23, 2016 | 07:43 AM
mknittle's Avatar
What you don't buy a new one every five years?
Old Apr 23, 2016 | 09:49 PM
MrFusion's Avatar
I do but they quit making them in 2001!!
I have owned 5 Cherokees over the last 8 years or so.
Old Apr 24, 2016 | 07:01 AM
mknittle's Avatar
Yeah, just when they got the bugs worked out of them they quit building them.
Dave88LX
61
Nov 23, 2014 02:17 AM
Boatnik
Aug 28, 2009 03:21 AM
ten8fiftyone
Jan 31, 2005 09:31 AM
Crabjoe
Mar 13, 2004 01:42 PM
rossn2
Jan 21, 2004 06:57 PM
