Old Dec 16, 2017 | 07:14 AM
  #5011
maybe368's Avatar
Originally Posted by NJTman
I bet you got your kicks....
I didn't know that there were shoe stores on route 66 ...Mark
Old Dec 16, 2017 | 09:02 AM
  #5012
There's a cereal factory as well.
Old Dec 16, 2017 | 09:48 AM
  #5013
maybe368's Avatar
I didn't even know that kicks meant shoes until this song came out about threatening a school shooting (no kidding) and I didn't know what "pumped up kicks" meant...Mark
https://www.google.com/url?sa=t&rct=...qxGXbmcfA872Va
Old Dec 16, 2017 | 10:06 AM
  #5014
Me neither. Great topic to make a song about .
No I didn't watch it, I just read the first few lines of lyrics
Old Dec 16, 2017 | 10:23 AM
  #5015
maybe368's Avatar
If you don't listen to the words, it's not a bad tune...Mark
Old Dec 16, 2017 | 10:47 AM
  #5016
MrFusion's Avatar
So, last night was my first opportunity to use my new spotlight.
Some goober was behind me while I was traveling from one of my plowing customers, and he / she / it has their high beams on, irritating me, riding my bumper. Activated my "anti-goober" reflection device, and they backed off 300 feet or so, Turnng their high beams off. I turned the device off. They got closer again, turning their high beams on again, and again I blasted them with my reflection device. They backed off again, I again turned the device off, and they stayed back, and didn't again use the I high beams behind me...
Success!!! Woo hoo!
I swear: It wasn't ME!!
Old Dec 16, 2017 | 10:49 AM
  #5017
MrFusion's Avatar
Didn't know there was an 80's hair metal band living on Rt 66...
Old Dec 16, 2017 | 04:22 PM
  #5018
edwinsmith's Avatar
Success!!! Woo hoo!
While that is really satisfying you should be thankful it wasn't a cop behind you. or you could be like this poor fellow.
Old Dec 16, 2017 | 06:35 PM
  #5019
More snow clearing
Attached Thumbnails What did you do to your Gen 1 today?-b.jpg   What did you do to your Gen 1 today?-bb.jpg   What did you do to your Gen 1 today?-before.jpg   What did you do to your Gen 1 today?-after.jpg
Old Dec 16, 2017 | 06:44 PM
  #5020
More snow clearing
How are you going to get your truck stuck up to the axles plowing that?...
Old Dec 16, 2017 | 08:11 PM
  #5021
I'll just drive up to your house if I really think it will make me feel better getting stuck
Old Dec 16, 2017 | 10:46 PM
  #5022
1stGEN'93's Avatar
Got it home
Today I drove my truck home from my grandparents as it seemed that the gunk had pretty well cleaned out and it was not dying on my anymore. Ran awesome for most of the way, about 1 1/2 hours, but then it started surging some and power went down. Figured the fuel filter was probably getting clogged so I limped it to somewhere where I could pull off and swap out filters. Changed the filter and filled the new one with Stanadyne Performance Additive. Started the truck and it still had a rough idle and was kind of cutting out some. Decided to just “SEND IT” and drove the rest of the way home. Power was down noticeably and when I got home the idle was still rough. Stopped in the driveway and left it in drive for a minute. The engine was lugging, but it didn’t die. Decided to check transmission fluid level just for kicks and giggles and when I got done the idle was still rough and stumbling. Old filter had some residue from the what has been recirculating from what was in the injector pump. Not a lot, but probably enough to clog the 4 micron fuel filters I run. Wondering if the lift pump got wiped out again from the little bit of stuff that is still running through. I have a warranty on the lift pump so I’ll have to check it tomorrow and take it back Monday if it is. I still have the receipt and the box it came in so shouldn’t be a problem there. I’d like to get some sort of fuel filter before the lift pump, but I worry that that would reduce fuel flow too much. It would be nice to have one to catch the big stuff that will wipe out a lift pump though.
Old Dec 17, 2017 | 01:41 AM
  #5023
1320Fastback's Avatar
Bought the two front seals for a Getrag in preparation of removing mine and changing them. My truck is leaking about 1/2 quart a week.
Old Dec 17, 2017 | 05:07 PM
  #5024
I run a cheap Fram G2 between the lift pump and fuel tank....the clear one so I can see the gunk it catches. Never noticed any reduction in fuel flow, my fuel pressure seems fine.
Old Dec 17, 2017 | 05:22 PM
  #5025
1stGEN'93's Avatar
Thats good to hear. Checked the lift pump and at first it wasn’t pumping so I rotated the engine just a little bit and then tried again. Sprayed fuel out the loosened banjo bolt on the inlet side of the filter housing. I then tightened that one and loosened the 10mm banjo bolt on the outlet side of the filter housing and it sprayed a little fuel out and then it seemed like the pumps were less effective. Almost like the pressure had built up to its maximum and it only sprayed out here and there. This is with a brand new filter. Only has 17 miles on it.
