Old Dec 9, 2017 | 07:00 AM
  #4951
Jim Lane's Avatar
Originally Posted by 73CrewCab
He falls asleep standing up, in mid-conversation!!! Kids these days I swear. I hit the driveway at about 30 MPH and he almost cracked his head on his knee... the day before, I cut into a dirt field and he woke up with me doing donuts. Ever hear a 30 year old wake up from a dead sleep in the middle of a 4th gear donut? We need a new guy at work....
Sounds like Mono
Mononucleosis
Hope you did not take a drink after him,
  #4952
mknittle's Avatar
Since my wheel bearing escapade yesterday, my brakes felt a little goofy. Since my master cylinder is the one that came on my 73 when I bought it 3 years ago (and I have no idea when it was last replaced), I picked one up at Vatozone and swapped it before running service calls..... and of course, mine had backwards ports and the new one didn’t. I found out when I went for a test drive and the rears would lock up and the front had hardly any power. I had bled the brakes the day before, and bled them again after replacing the master. Then had to cut the 2 main hard lines and swap the fittings, re-flare them and re-bleed the system again. I’ve gone through 3 big bottles of DOT-3 in 2 days. This weekend, I’ll be re-making one of the main lines and bleeding it again, once I get some more DOT-3..... maybe I should do the Chevy rear wheel cylinder upgrade while I’m at it, so I don’t have to bleed them for the 27th time.... I need a beer.
why not go hydroboost?
Old Dec 9, 2017 | 07:06 AM
  #4953
Jim Lane's Avatar
Originally Posted by NJTman
Finished my cargo lamp bracket. Dropped it off at the powder coating co.
Need to see how I'm going to wire it, as I don't want to overload the wiring in the roof area. Trying to get the specs on these units is a pita.
Pull a 12-gauge wire from the fuse panel to the light and tuck a 30-amp Tyco relay behind the light,#85 and #86 connect to the old light wires to trigger the relay.
Simple
Old Dec 9, 2017 | 10:34 AM
  #4954
Originally Posted by BHD
NJT, I know you love that white stuff. Hopefully, for your sake, you get a little to play in. I've been in Georgia for a while, and I ain't missing winter.
It's been snowing for about an hour now.
Nothing sticking, except for vehicles and grassy areas.
I hear that parts of the south are being hammered by this storm. Places seen more snow than in several decades, or since recorded history of weather there.
Go figure, eh ?
Safe travels home.
Old Dec 9, 2017 | 10:38 AM
  #4955
Simple
I'll follow that, and add a little more.
The cargo lamp switch, I'm going to replace with a 3 way
(God, I've always wanted to do a three way)
Anyway, the local guys here are running their back up lamps to the three way switch, so that essentially, if in position one, it works anytime you throw the switch. In position 2 it does nothing, and in position 3, your reverse lights automatically trigger it on, so as you're backing up, you get a very nice clear view going backwards..
Simple, yet awesome....!
Thanks again, Mr. Jim
(have to show my respect for you)
Old Dec 9, 2017 | 03:36 PM
  #4956
73CrewCab's Avatar
Are you using the clear tube and bottle technique?
Are you sure all fittings are sealed right, and not sucking air?
The replacement master is new or rebuilt?
I assume bench bled? Did you bench bleed and depress plunger full depth, or partial depth when on the bench?
Lots of silly little details that make or brake these systems.
Yep, Yep, New, Yep, Full depth. I figure the old one was bad because the rear reservoir was over full, and the front was about empty. The fluid must have bypassed internally, is my guess.
Hydro boost is in the future when I have time and money. I definitely want to change to stronger axles (2nd Gen D60/D70 under it now) as well as bigger brakes with rear disc, then I can think about doing more to the motor. Whoa before go.
I never have, nor ever will share a glass with another man... I’m not from THAT part of CA
Old Dec 9, 2017 | 03:44 PM
  #4957
I have been through the same thing, so I started buying DOT-3 by the gallon.....
Old Dec 9, 2017 | 03:51 PM
  #4958
Morsel's Avatar
Installed a new heater blower motor today by golley!
Old Dec 9, 2017 | 08:46 PM
  #4959
BHD's Avatar
BHD
Go figure, eh ?
Safe travels home.
Thanks. A friend lives NW of Atlanta said they had 10 inches. That pretty much shuts everything down.
Old Dec 10, 2017 | 04:25 AM
  #4960
Okay...
Full depth in bench bleeding stroke "may " be an issue.
I read about 15 years ,ago that mechanics, who bench bled their master cylinders, who depressed the piston full depth, tore the inner seals inside the master by doing so, causing a air / fluid leak between the front and rear port passages. Since then, my own bleeding process has only depressed the piston in 3/4 " to 1 " deep, and all my " master cylinder" issues are gone.
The only way to know is to disassemble the piston from the assembly, and see if its torn or not. Personally, I would look at the master cylinder as being the culprit, as a last ditch effort only. I would look for air entering elsewhere first.
Old Dec 10, 2017 | 04:30 AM
  #4961
Not enough snow to do a lot of my customers, but it does look purty....
My outdoor trees...
Attached Thumbnails What did you do to your Gen 1 today?-1209171835a-768x1365-1.jpg
Old Dec 10, 2017 | 03:00 PM
  #4962
73CrewCab's Avatar
Okay...
I never bench bled the OLD master. It never came off the truck when I did the CTD conversion, only the 2 main lines got re-made (which go down to a 2nd gen residual/proportioning valve, then heads to the wheels). I did “bench bleed” the NEW one, but I did it in place and used the pedal to slowly push in and out with. The new one works great, once I figured out that the ports were backwards. The old reservoir was 50/50 in size and the new one is about 75/25 in size, with the small portion being for the rear brakes. I just need to remake one line, as it’s almost straight and doesn’t leave much room for firewall flex. I figure, if I re-make a line, I’ll need to re-bleed again, so I might as well upgrade the rear wheel cylinders to the larger bore Chevy version. Need to see how much life that the rear shoes have anyway.
Old Dec 10, 2017 | 03:01 PM
  #4963
73CrewCab's Avatar
My outdoor trees...
Sure does look nice. I’ve got family in Rome, GA and they’re saying some of the roads are shut down around there. Welcome to Winter!
Old Dec 10, 2017 | 04:59 PM
  #4964
Me rikey rinter, wong time....
Attached Thumbnails What did you do to your Gen 1 today?-1210170737_20171210175656161.jpg
Old Dec 10, 2017 | 06:03 PM
  #4965
Ol-dodge 1992's Avatar
Hey NJT ... sharp looking ride ... is your paint factory cause mine is factory and it is opposite yours
Grey stripe on white body with red pin stripe as an accent... I've seen a ton with my paint scheme but none that I can remember like yours
SD
