wh1c with big head actuator
Old Sep 7, 2007 | 03:10 PM
ol' 93 12 valve's Avatar
i just recently put a wh1c on my 93 12 valve cummins 5 speed. my only problem is that i push 30-31 pounds of boost and my banks big head actuator is set for 43 pounds of boost. Can i manually adjust this actuator? Or do i have to get a different actuator?
Old Sep 7, 2007 | 05:00 PM
G1625S's Avatar
How are you sure that its set for 43psi? Assuming 43psi is the setting, it sounds like you need more fuel to get to that level. Truthfully, 30psi is the sweet spot for the wh1c. if it were my turbo, I'd be happy with it
oh, welcome to DTR--nice to have you along!
greg
Old Sep 7, 2007 | 11:59 PM
whereswaldo250's Avatar
Great to see you hear
Old Sep 9, 2007 | 08:46 AM
GLHS's Avatar
The Banks head can be adjusted up to 43 psi or down to ???. Your just reading the sticker on the actuator. I never connected the hose for my Big Head actuator because the more boost my truck had, the cooler and better it ran.
Old Sep 10, 2007 | 06:07 PM
right now i dont have the actuator hooked up. should i leave it alone or hook it up? By the way it does run excellent at 30-31 pounds.
Thanks for havin me here!
Old Sep 11, 2007 | 11:29 AM
Lil Dog's Avatar
I would leave well enough alone. If the wastegate is closed at 30 psi, thats all good. The H1C as well at the HX like to be below 35 psi for optimal performance, so no need to adjust.
dochawken
Nov 14, 2012 09:39 PM
biggator60
Jun 4, 2008 02:06 PM
wannadiesel
Apr 27, 2004 06:32 PM
gdh11
Mar 8, 2004 05:45 AM
boostnCummins
Jul 26, 2003 03:26 PM
