Factory Tach?
Old Sep 10, 2007 | 02:11 PM
CaptainChrysler's Avatar
Factory Tach?
Could you get a factory tach in 91? I am looking at one and the guy says about the only option it has is a tach. Is it out of the question to put a/c and cruise on one of these?
Old Sep 10, 2007 | 02:40 PM
rbrettctd's Avatar
91.5 you could, intercooled model in other words. Cruise is not hard, now a/c may be a bit of a challenge. I think there are aftermarket systems available or once available but dont know if they still are.
Old Sep 10, 2007 | 02:44 PM
mhuppertz's Avatar
I'm fairly certain a tach was avaliable in '91, but really hard to find for any 1st gen.
The best way to do the air is a donor Dodge from the same era. The cruise is tied in with the PCM on the '93s, but I know the early 1st Gens had a mechanical speedo, so it might be possible to retro fit one of those. I will look at my schematics tonight.
Old Sep 10, 2007 | 02:48 PM
If it does have a factory tach, where did they put them?
Old Sep 10, 2007 | 03:14 PM
rbrettctd's Avatar
On top of the dash next to the a pillar. Check out the 'gauge pod pics' thread someone started that is just below this one for a pic of one.
Old Sep 10, 2007 | 04:02 PM
The "factory" tach was a dealer installed (or DIY) Mopar accessory for '92 and '93 trucks. The older trucks don't have a crank sensor.
Old Sep 10, 2007 | 08:57 PM
RumbleFish's Avatar
My early 91 had a factory tach in it. Getrag with a crank sensor.
Old Sep 11, 2007 | 04:38 AM
KRB's Avatar
KRB
If its got a factory tach or even a factory installed tach, then that is worth the price of AC & cruise . OEM tachs go for the price of half a dozen aftermarket ones sometimes!
Do like rbrett said and compare to the previous post's picture.
Old Sep 11, 2007 | 11:28 AM
max924's Avatar
my factory (or dealer installed) tach is located above the 4wd indicating light on the dash
Old Sep 11, 2007 | 12:11 PM
dodgeb1b's Avatar
my 91 non IC truck has one, A/C and cruise to!
Jim Shulmister
Jan 12, 2007 05:16 PM
vavtx
Nov 27, 2006 04:17 PM
timb
Feb 4, 2006 10:17 AM
andyr354
Oct 30, 2004 11:39 PM
TexasBlake
Aug 15, 2004 05:28 PM
