Is this the factory tach wiring harness?
Old Aug 15, 2004 | 05:09 PM
TexasBlake's Avatar
I got the three guage dash pod and a 5k diesel tach from a buddy of mine the other day. I have a 93' and I read that it was supposed to have the wiring harness for the tach already. I can see the crank position sensor, so I went looking for the wiring harness. This is the only 4 pin flat connector I can see, and it seems to be the same colors that I need. Just want to confirm that this is the right wiring harness for the tach so I can go ahead and order the Isspro harness.
Old Aug 15, 2004 | 05:15 PM
jiMMyCTD's Avatar
assuming you found it on the left had side as you look at teh wheel that should be it. but make sure the tach you got uses that type of sending unit as well.
you can always save some money and just wire into teh plug yourself.
jiMMy
Old Aug 15, 2004 | 05:20 PM
TexasBlake's Avatar
You jiMMY from PBB? You've gotta be
I've got the aftermarket crank position sensor, I just need to et some magnets to put on teh crank. I figured if this thing was already wired, I'd just use the factory stuff.
But yeah , Ifound it right by the steering column. This Isspo should use it, cause they have the harness available. I guess I'll call Isspro tommorow to make sure.
Old Aug 15, 2004 | 05:28 PM
jiMMyCTD's Avatar
That would be me......
Just went and looked at mine again. that is the plug u need.
jiMMy
RollinCoalSmoke
Apr 13, 2018 11:19 AM
Harvie
Apr 3, 2009 06:42 AM
wyododge
Jan 13, 2009 02:25 AM
shrmpboatcptn
May 3, 2007 12:33 AM
