Wiring a pillar guage(s) into factory harness
Old Mar 28, 2009 | 04:13 PM
Harvie's Avatar
Could someone wire a pillar mounted guage light(s) into the factory wire harness plug, for the overhead cab clearance lights, under the factory driver side a pillar trim pannel, for on off use when hl/running lights are turned on?
What would the ground and positive, for the gauge light, be wired into (color code for the factory pos and neg in the wire harness) for a factory plug connection (without the outside cab lights).
What would be the part numbers for the factory matching plug and pins, for the soildering onto a gauge, to plug into the factory harness?
2009 3500 Quad Cab
Old Mar 28, 2009 | 10:03 PM
TonyB's Avatar
Sorry, don't recall where I tied into the factoy lighting...I think it was the backlight for the center console in the instrument panel.
Here are the wiring diagrams.
Tony
Old Mar 30, 2009 | 07:41 AM
Jim W's Avatar
When I installed my gauges with the A pillar mount I tied the lights into the instrument dimmer switch wiring. In this way when I want to dim the instrument lights the additional gauge lights will dim also.
Use a test probe and dim your instrument lights to find the correct wire.
You can also do a search on this or another site and find instructions on how to do this.
Old Mar 30, 2009 | 11:19 AM
Lil Dog's Avatar
I was curious also. Its not as easy as the old truck was for finding a power point.
Old Mar 30, 2009 | 02:03 PM
Harvie's Avatar
I know how to tie into the cig lighter dimmer switch and ground them, that is not the question in this post.
Tieing into the factory a pillar, harness is.....
Old Apr 3, 2009 | 06:42 AM
Harvie's Avatar
I figured this one out too so you can delete this also.
svtrich
Nov 17, 2007 06:33 PM
shrmpboatcptn
May 3, 2007 12:33 AM
J114
May 7, 2006 12:28 AM
getblown5.9
Apr 7, 2005 06:36 PM
TexasBlake
Aug 15, 2004 05:28 PM
