Water meth and white smoke?
Old Mar 6, 2008 | 04:54 PM
ryan10's Avatar
Hey guys, i have my water meth set to kick on around 15 psi, and then the boost gauge rises to 20 real quick, but over 20lbs with the water meth on it will blow some white smoke. with the water meth off, no smoke. what is causing this. the egts are about 850-900 during this.
thanks.
Old Mar 6, 2008 | 05:26 PM
Sounds like you are pumping in a little too much. Does the truck run OK?
Old Mar 6, 2008 | 05:29 PM
Dean Snow's Avatar
I agree with Wanna. I see it says you have 2 nozzles on your water meth. Try unhooking one and see if it still does it. Then you will know if you need smaller nozzles for it.
Old Mar 6, 2008 | 05:40 PM
ryan10's Avatar
Ok, thanks.I will try this. The truck seems to run a little rough when it does this. I have 2 12gph nozzles in it now, I also have 2 6gph nozzles. Should i switch these out?
thanks.
Old Mar 6, 2008 | 05:43 PM
Try one 6 and one 12. It should run smooth on the water/meth, roughness is a sign that you're spraying too much and "putting out the fire."
Old Mar 6, 2008 | 05:49 PM
ryan10's Avatar
Ok, thanks. Im going to go give this a try. ill let you know.
Old Mar 7, 2008 | 05:09 AM
ryan10's Avatar
Ok, i replaced one of the 12gph nozzles with a 6 and it seems to run a lot smoother, and it is no longer putting out the fire.
thanks.
SOhappy
Sep 4, 2014 03:35 PM
sleeperman
Mar 8, 2011 02:56 PM
jdpiii
Jun 19, 2008 07:34 AM
BlackSheep5
Nov 27, 2006 07:52 PM
dhe9
Nov 14, 2003 07:31 AM
