wait to start troubles
Old May 13, 2008 | 10:02 PM
dieselbryan87's Avatar
i just bought a 1991 dodge W350 cummins automatic. when i bought it the wait to start light didnt work. i checked the bulb and it was blown so i replaced it and now the light wont turn off it stays on until it fires up then starts blinking it never goes out. the truck always fires right up. any sugestions would be greatly appreciated. thanks Bryan
Old May 13, 2008 | 10:57 PM
Lil Dog's Avatar
My 89 did that when the intake air temp sensor got wet connections. Pull the plug on the sensor and give it a shot of WD-40 or similar lube. Also there are 2 harness connectors at the firewall to the engine right above the intake manifold that get a shot of water when you open the hood. Pull them and give them the same treatment.
Good luck and Welcome to the DTR!!
Old May 14, 2008 | 08:10 AM
jthorpe's Avatar
DTR Founder
If your truck is running, then please post in an area other then the Help! section...
Moved to appropriate forum.
Old May 14, 2008 | 08:39 AM
thanks, i tried that this morning and it still does the same thing. do you think i could be the air temp sensor?
Old May 14, 2008 | 05:44 PM
On a non-intercooled truck, if the temp sensor circuit is an open circuit, the WTS light will flash. Check the sensor with an ohmmeter to see if the sensor is open.
Bobcat698
13
Jan 24, 2008 08:45 PM
jriggs_18
Jan 11, 2007 04:43 PM
loosendend
Sep 4, 2006 12:01 PM
bfarrell
Nov 30, 2005 03:23 PM
59FORD
Aug 10, 2005 08:09 AM
