Wait to start flashing
Old Dec 17, 2008 | 10:55 PM
snowjoker's Avatar
I was out plowing this morning and after a couple hours the wait to start light started flashing. So i shut the truck down and restarted it and it stopped.. So I keep on plowing and it did it again a short time later. So i shut the truck off again and restarted it again and it never came back on.. Any Ideas ?
Old Dec 18, 2008 | 01:20 PM
snowjoker's Avatar
nobody knows ??
Old Dec 18, 2008 | 01:27 PM
HappyCamper's Avatar
From alldata,
"The Wait-To-Start lamp will flash ON and OFF if the charge air temperature sensor input to the engine controller is above maximum value or below minimum value. If either of the previous conditions occur, a fault code will be stored in the engine controller's memory."
Old Dec 18, 2008 | 05:02 PM
W150CTDproject's Avatar
Ooo. mine does that all the time. My relays are bad too. Piece of crap, If i leave the orange/ black, black, yellow/black, and black wires located on the driver side of the relays connected, it drains the battery FAST and they click while the truck's running. Also if it drops below say 30 degrees F, the grid dont work. And wont let it charge with the truck running. Unplugged em, worked fine but now the grid heater is out of service till i find new relays. My water in fuel, anti-lock, and Brake light is on too. There isnt any water in fuel and nada's wrong with the brakes, or anti-lock except that it dont work lol. OH! and the speedo dont work, or it bounces sometimes....sometimes. It's a fricken mess.
Old Dec 18, 2008 | 05:25 PM
The air temp sensor circuit is open. Bad sensor, bad wire, or just plain unplugged.
Old Dec 18, 2008 | 06:00 PM
snowjoker's Avatar
Thanks guys, IT probabbly is from the plow tripping, because when it comes back it slams hard... Very Hard... It has not done it since the 2nd time, so must have jarred the wire lose or something...
edwinsmith
Apr 16, 2021 03:56 PM
boneyards
Aug 17, 2006 07:43 AM
jeepsuck
May 17, 2006 11:05 PM
SmokenRam
Jan 3, 2006 06:31 PM
bfarrell
Nov 30, 2005 03:23 PM
