Wait to start light FLASHING!!
Old Dec 30, 2005 | 02:16 PM
SmokenRam's Avatar
It did this for about 2weeks, sometimes it would do it, sometimes it won't. Now its all the time!! If you just turn the key on, Light will just stay on and won't go off, once you start it, it flashes on and off!!! Anyone know anything about this?? Its a 98 12v, Thanks Chris
Old Dec 30, 2005 | 04:12 PM
Gunrunner's Avatar
don't know if a 98 is same as a 92, but on my 92 if you unplug air temp sensor (thermistor), wait to start light stays on for full 30 seconds, (so does grid heater), regardless of temp, then wait to start light flashes. Unplugging the thermistor is actually the test procedure for the thermistor. Try checking thermistor connection.
Old Dec 30, 2005 | 05:32 PM
AggiePhil's Avatar
Oh man, this sounds bad...
Old Dec 30, 2005 | 06:06 PM
Buckshotmckee's Avatar
It could be a bad relay.
Old Dec 31, 2005 | 09:33 PM
redhauler's Avatar
yep sounds like a possible heater grid or controler kinda like ABS light
flashing a code .
Old Dec 31, 2005 | 11:02 PM
Bad Ramer Jamer's Avatar
Did you check for any code's.
Old Jan 3, 2006 | 06:26 PM
SmokenRam's Avatar
Well i think i found it. Its the Air intake temp sensor. Tried my budies and it takes care of it!!
Old Jan 3, 2006 | 06:31 PM
AggiePhil's Avatar
Wow, props to Matt Auge!
edwinsmith
Apr 16, 2021 03:56 PM
lbdoc76
Jan 27, 2009 10:16 AM
boneyards
Aug 17, 2006 07:43 AM
jeepsuck
May 17, 2006 11:05 PM
bfarrell
Nov 30, 2005 03:23 PM
