wait to start light flashing while at highway speeds
Old Aug 14, 2006 | 08:51 AM
boneyards's Avatar
on a 92 ctd the wait to start light will sometimes flash at highway speeds, esp. under load. If I ease up on the throttle, the light goes out and may stay out. any suggestions
boneyards
Old Aug 14, 2006 | 08:44 PM
HappyCamper's Avatar
According to Alldata,
The Wait-To-Start lamp will flash ON and OFF if the charge air temperature sensor input to the engine controller is above maximum value or below minimum value. If either of the previous conditions occur, a fault code will be stored in the engine controller's memory.
Does it only happen on hot days? How is your air intake housing? Any cracks or air leaks inside the engine compartment? BTW - 59*F (15*C) is the low end, I am not sure what the max value is. Perhaps someone can chime in...
I am not an expert - haven't seen this error, but it can't hurt to check.
Old Aug 15, 2006 | 06:59 AM
boneyards's Avatar
I have only had the truck for a few months now, so I can't speak about the colder temp. The air intake seems fine, I have a new k&n filter on. It gets warm here (Ontario), but not excessively so. The dealer here is unable to give me any advice. I may have a problem with the vacuum, (cruise control does not work), but other vacuum operated items do.
I will try to see if a code is set.
Thanks
Old Aug 15, 2006 | 03:51 PM
Probably a bad wire or a bad sensor. It's supposed to flash if you unplug the sensor.
Old Aug 15, 2006 | 03:55 PM
Micaiahfied's Avatar
i can second what wanna has to say. its the sensor on the top of the motor, drivers side, closest to the intake horn. if you unplug it the light will flash. start there and check the connection.
Old Aug 17, 2006 | 07:43 AM
boneyards's Avatar
Thanks, although the engine light was not on a stored code suggested air intake temp sensor is malfunctioning. I believe this is the one mentioned in the posts. Thnaks for the help
boneyards
edwinsmith
Apr 16, 2021 03:56 PM
lbdoc76
Jan 27, 2009 10:16 AM
jeepsuck
May 17, 2006 11:05 PM
SmokenRam
Jan 3, 2006 06:31 PM
bfarrell
Nov 30, 2005 03:23 PM
