1991 W250- Which cabs and front clips will work?
Old Aug 16, 2006 | 02:33 PM
AFK's Avatar
AFK
I have a 1991 W250 Regular cab that I would like to swap out the cab and front clip on. Disregarding the variations in the grilles and such, what years can I use to interchange parts? I plan on having it a flatbed so I'm not interested in the box.
This is my first Dodge product ever so I don't know much of anything about what changed over the years. There are 2 possible parts trucks I have my eye on right now- 1988 W250 and a 1984 D150. Both are regular cabs like mine. They all look more or less the same to me but I want to make sure they are compatible.
I am not real concerned with my 1991 not looking like a 91 ie- grille, hood ornament, etc; I can deal with that stuff later. Right now I just want to know what parts I can use so I can start narrowing my search.
-AFK
Old Aug 16, 2006 | 03:51 PM
G1625S's Avatar
is your '91 intercooled? If so, you must use that grille/core support. After that, anything earlier than, I think, 83, will have slightly different body lines, but since you're going flatbed, you can pretty much slap whatever cab on there you want.
Old Aug 16, 2006 | 04:25 PM
Winr's Avatar
'81 and up all have the same body lines. The magor differences are the position of the head light buckets on the '81 -91 (also different grills) and the door latches, hood hinges are different thru the years as well.
Look on my pics I have an intercooler behind an '83 grill mounted on a '92 core support. The '86-'91 grills would need too much triming to look good.
All that being said, you can use any year cab,doors, fenders, ('81-'93) as replacements but keep the Hardware (hinges, latches ect..) from the year you want to maitain
Old Aug 16, 2006 | 05:46 PM
There were some body changes in '85, all things being equal I'd use the '88.
Old Aug 17, 2006 | 09:15 AM
FNJ's Avatar
FNJ
cab swap
I just did a cab swap on my 90 w250 I used a cab from a 93 d250 the only difference is the trans hump in the floor 4wd has a larger hump 2wd has the small hump all u have to do is relocate the hole for thr 4wd shifter also when I did the swap I kept the dashboard from the old cab and installed it in the new cab because of the vin number.
Old Aug 17, 2006 | 09:24 AM
derek840378's Avatar
you can use a cab from all the way back to 72, but the body lines wont match
kerry.king
60
Mar 24, 2013 10:23 AM
shaunbolton
Aug 5, 2009 07:26 AM
bimmerboy86
Mar 2, 2007 01:40 AM
redwake9112
Aug 9, 2006 03:11 PM
91.5CTDBanks
Aug 8, 2006 09:37 AM
