Very Very Happy
Old Aug 8, 2010 | 09:52 PM
1STGENFARMBOY's Avatar
Very Very Happy
I have been fighting white hot EGT's since i maxed out my VE, with 80hp DDP sticks, 4in dp to 5in stacks, 16cm housing and 14psi of WOT fuel, 3/16 timming, BHAF, 29psi boost, my pyro would fly by 1600* like a mile post so i installed a P/S intercooler and 3in cooler tubes 1525* was max, so yesterday i installed Gillett's 60mm upgrade and my boost went to a strong 38psi and today i made some good long 95mph run's and praise the Lord 1250* is it, I;m so happy about that, anyhow i'm gonna tow some heavy loads this month so cross your fingers, oh and by the way now i need a good tight converter, hopfully my stock converter is not the reason my EGT's are low,
Dar
Old Aug 8, 2010 | 10:49 PM
TLRMAN's Avatar
Adding a good converter will help your engine temps and the pay off will be a little better egt.
But as you add power later that egt will go back up ...
Old Aug 8, 2010 | 10:59 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
EGT's what are those??!!
Old Aug 8, 2010 | 11:03 PM
If i put a good tight converter in won't it load the motor more and cause the egt's to go up a little?? I hope your right and they go down more, and i won't be adding more power i'm done, i just want to be able to use what i have, i'm guessing here but i may have 300-330 hp, when i get my a good converter and shift kit and a few pump adjustments and band adjustments i'm gona put it on a dyno just to see. I just gota be able to drive it and tow some heavy stuff, 10,000-16,000lbs.
Dar
Old Aug 9, 2010 | 04:57 PM
bradshaw106's Avatar
wow!! 95mph I wouldnt dare go that fast... your truck must sound like it will explode. mine does at about 75
Old Aug 9, 2010 | 05:02 PM
Onemoparnut's Avatar
The converter will make egt go up. When I put mine in it went up. Before I could not get to 1250 to save my life. Now all I changed was the converter and a lot of parts in the trans I can get to 1500.
Old Aug 9, 2010 | 05:30 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
lol i go 95 in 4th gear, hit 5th and burry the speedo and watch the EGT's... (on closed courses of course)
Old Aug 9, 2010 | 06:05 PM
Rick 12v CTD's Avatar
my speed really tapers off around 90-95 in OD but I got the stock auto with a stock converter and VERY VERY bald 235-85-r16 tires that are kinda small. They literally look like slicks and their dia. is probably down to 30.25" lol. I should put my good 255/85/16 toyo tires back on but they are my winter tires.
Derek Edgar
Apr 10, 2013 09:54 AM
QWKRTNU
Jul 28, 2006 04:05 PM
John Faughn
Feb 2, 2005 07:16 PM
converteddzlr
20
Nov 29, 2002 09:48 AM
