vent windows
Old Jan 26, 2008 | 07:45 PM
Kev_n_AZ's Avatar
vent windows
anyone have an assembly schematic for the vent window latches on the 1st gen trucks?
my passenger side vent window latch had total failure and I have a replacement. the new assembly has questionable parts with noe directions.
thanks!
Old Jan 26, 2008 | 09:03 PM
BC847's Avatar
1st Generation Admin
This is what the Dodge parts guy/gal would have looked at.
Good luck.
And that's it.
My driver's vent latch is worn out (shaft).
Old Jan 27, 2008 | 01:54 AM
Kev_n_AZ's Avatar
the vent window latches are available at dodge fairly inexpensive.
I will post a pic of the parts and give ya the part # to get a new one .
I just am not figuring out where this little piece of metal goes...
pic coming soon...
Old Jan 28, 2008 | 12:48 PM
AUGIE DOG's Avatar
Hey Ken, do they have the rubber gasket that seals the wing window when you close it? Mine leaks on both doors and water runs down the door and soaks my carpet. As a result of that my carpet is rotted and falling apart. So far that is the only leaks i can find in the cab. This cab style is notorious for leaks. My 82 stepside did the same thing. They also leak around the cowl and leakdown the firewall inside the cab. I was told the gasket around the wiper motor is the culprit. I've seen door gasket and seals around door windows but none for wing vent.
Old Jan 28, 2008 | 02:20 PM
Kev_n_AZ's Avatar
call Dodge for the window gaskets...
Old Jan 1, 2009 | 03:26 PM
samiam4's Avatar
So is that 43546467 weatherstrip the triangular piece for the vent window?
Is it still available for a reasonable cost?
Michael
Old Jan 1, 2009 | 04:33 PM
ofcmarc's Avatar
Try this.....
https://www.dieseltruckresource.com/...d.php?t=191213
Old Jan 1, 2009 | 10:42 PM
AUGIE DOG's Avatar
Samiam4 the gaskets are available from Dodge. I have a friend who is the manager for Rick Hendrick Dodge Auto body here in North Carolina and i just gave him my vin # and he got the gaskets. If i remember they were about $125.00 for two gaskets. There are other body / trim parts still available. I hope that helps. Part # is 4354607 and they are made in USA!! I hope that number is good i took it off of packaging. If not let me know.
Old Jan 2, 2009 | 04:35 AM
keith1992's Avatar
Can you buy a new handle only from dodge? Whats the part number for that? Is that the 4240 998-9?
Rednecktastic
Nov 15, 2010 09:29 PM
bigfoot
Jan 1, 2010 02:22 PM
97catintenn
Aug 7, 2009 08:23 PM
04ctd
Dec 23, 2006 08:23 PM
markster
Oct 7, 2006 02:20 PM
