Ve pump interchange question.
Old Oct 13, 2009 | 07:48 PM
  #31
Sure, won't take but a few minutes to swap that stuff around.
Old Oct 13, 2009 | 08:14 PM
  #32
JD730's Avatar
The non-IC lines and IC engines use different line routing. There's stuff in the way of doing a swap.
If you try to put a non-IC pump on an intercooled engine, the trouble you run into with the lines is that they are near impossible to install because the ends of the delivery valves are too far back.
I have a set of non-IC lines on my 93 with a non-IC pump, I also ran it with the IC pump. I had to make a new throttle bracket that bolts to the head and I can tell you it is not worth the trouble involved.
Old Oct 13, 2009 | 09:09 PM
  #33
So what are you saying Mike? Just swap the DV holders from the 93 pump to the 89 pump? not the lines and stuff
Old Oct 13, 2009 | 09:18 PM
  #34
JD730's Avatar
Yup
Old Oct 14, 2009 | 06:24 AM
  #35
Alright, thanks for all the help guys
IRoss
Jun 30, 2010 02:18 PM
crewcabxlt
Nov 11, 2009 09:14 AM
Jungle
Aug 24, 2009 10:49 AM
Trebor
May 18, 2007 08:19 PM
Trebor
Dec 23, 2006 12:17 PM
