Vac/power steering pump interchange?
What years on the vac/power steering pumps will bolt onto a Dodge 1993 CTD with IC? Will say a 1999 pump assemble bolt on to the 99? Any concerns to think about? I was thinking about putting the Saginaw style pump on it.
Thanks guys!!
Jim
Thanks guys!!
Jim
Basically you can bolt wich ever one you want on there, 89-02. There are several different styles thru the years. The newer ones from trucks with hydro boost brakes don't have the capacity to run the vacuum brakes on your '93. The non-IC ones are a little different, and I would avoid them.
http://fixinrams.com/
^ This place has some good info on them, and parts. You can get a seal kit cheaper from cummins though.
jared thompson
14
May 10, 2011 12:23 AM
Common
Dec 15, 2008 07:38 AM
