turbo help
turbo help
i know ive seen it in a forum some where but im trying to figure out the best setup on my 93 turbo. im using it to pull heavy loads and the spool on my stock turbo is god awfull. im lookn for the exhaust and intake side setup for my application. THANKS
The heavier the load the more air you want to cram down its throat to keep EGTs in check. Go at least 60mm+ on the compressor wheel and don't choke out your exhaust with a tiny housing.
The best exhaust housing for you will depend on if the truck is a 5speed or automatic. The auto trucks its allot easier to keep spooled. If you have a 5 speed I say find a used HX35 for cheap and put the 60mm compressor side drill out the divider in the 12cm exhaust housing and put it on. If you have a auto truck put the 60mm housing on the H1C and leave the 18cm exhaust housing on. That will be your cheapest route unless you can find a used 12cm (for your 5 speed if that's what you have) put that on your H1C along with the 60mm intake and you should be good. You could probably get away under $500 if you shop around but the cheapest 60mm will be from GDS.
CumminsRedneck
Jul 6, 2013 03:20 PM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
