ve problems
Old Jul 16, 2011 | 05:03 PM
jmadisonw250's Avatar
ve problems
ok I was reading on here and came across where it said that the ip pump will have a low idle when it starts to get worn out and only when it is hot well that was a bummer to me because mine is doing this and when i push on the brakes it sometimes will die then it will crank and crank over for awhile then it will start not the usual rolls over once or twice and it is started. So am i looking at a rebuild shortly or what?
Old Jul 16, 2011 | 11:57 PM
Well if your truck is dying when you apply your brakes, then you might have an issue with your Vacuum/power steering set-up. But if the idle is really low then you could potentially cause the motor to die when the load on the power steering/vacuum pump is too great.
Do you have any leaks from your IP? And how low is your idle?
Old Jul 17, 2011 | 09:48 AM
well i dont have a tack but it is very low and it dont die all the time
Old Jul 17, 2011 | 09:52 AM
and i have not seen any leaks
Old Jul 17, 2011 | 12:45 PM
Could you fill out your signature, about your truck, so we can see what you have, and how it's optioned. That can aid us too in trying to diagnose problems as well.
Does your truck idle higher when it's first fired up, then slowly loose RPM as it gets warmer?
Old Jul 17, 2011 | 07:00 PM
how might i do that
Old Jul 17, 2011 | 07:17 PM
maybe368's Avatar
Originally Posted by jmadisonw250
how might i do that
Click on the user cp link near the top left of the page. Then click on edit signature. Sorry, I don't know much about the IP...Mark
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
olgraybeard
Mar 24, 2003 06:32 AM
Dwight
Mar 18, 2003 08:14 PM
