valve cover breathers
does anyone have any pics of some cheap valve cover breathers that they installed on their truck i want to put a couple on mine they cant be the open element type though i mud with the truck thanks
You can supplement the stock/OEM crankcase vent on the lifter-valley cover with one from a 24v CTD. The 24v version mounts to where we pour oil in. You can move the oil fill to a valve-cover (using a valve cover from an industrial Cummins, or just cut yours off it's pipe, drill a hole for it in your current valve-cover and epoxy it in place).
wanna when running more boost isnt it necessary to get better crancase ventilation for piston ring seal or should i not beworried about this i dont have a lot of blowby but i do have a little oil residue on the breather tube under the truck thanks for advice
ok sounds good i was just thinking about it when i was going to be tightening down my head bolts since i have to take the valve covers off would it hurt or is it overkill? also wanna what do you suggest on the headbolts taking them all the way out and retapping the holes and cleaning them out or do you think i could just tighten them?
? You can't really watch it while your driving
Forrest Nearing
20
Dec 25, 2006 10:19 AM
got...DIESEL?
Jun 27, 2005 01:55 AM
