valve clearance??
Old Jun 4, 2009 | 08:13 PM
powerram93's Avatar
valve clearance??
Hey, guys, I'd like to know what you set your valves to, and how often. I really need to do valve cover gaskets, and while I'm there....
Old Jun 4, 2009 | 08:40 PM
roxxx's Avatar
here you go I think it is every 25000 miles {edit} oops 24 000 miles
http://dodgeram.org/tech/dsl/valve_adj/12_valve.html
Old Jun 5, 2009 | 11:03 AM
powerram93's Avatar
Thanks! That link should help it go pretty well; just have to find the time.
Old Jun 5, 2009 | 11:22 AM
ppiggppenn's Avatar
.... find some knee pads while you're at it, .... took me quite a while and my knees had to be parked on the rad brace for the whole time.
Old Jun 5, 2009 | 10:57 PM
Alwaysworking's Avatar
alwaysonDTR
i stand on the frame rail next to the turbo
Old Jun 6, 2009 | 08:58 AM
ppiggppenn's Avatar
lol AW, .... I'd be lucky to get two broom handles down past my turbo, ... I'll have another look tho as rereading the "companion cylinder" method I think I left my gaps too big. Says the gage feeler is supposed to drag with a few inch-pounds on the screw. I brought mine in to just touching, extra cautious but still too rattly.
Old Jun 6, 2009 | 09:11 AM
jimbo486's Avatar
leave the feeler gauge under the rocker, tighten to 6 in lbs and lock the jam nut. should be fine. that's how i was taught in my diesel class. 6 in lbs was what the N14 cummins specs were when adjusting valves. just thought i'd throw that out there.
Old Jun 6, 2009 | 07:58 PM
ppiggppenn's Avatar
... thanks for that Jimbo, ... powerram should be all set to go and I can't wait to get back at mine and do it right, soon as I find my kneepads
Old Jun 6, 2009 | 11:12 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
I set mine at 8 and 18 and do it every time I do a headgasket which is pretty often
I actually thought about setting them again tomorow for giggles
Old Jun 7, 2009 | 01:00 PM
roxxx's Avatar
If you are having troubles with the feeler gauges use the under and over method .... one size up of a feeler gauge and one size under , that way you get a better idea of the proper feel of the right thickness . Little more time consuming but you sure get it right
Old Jun 7, 2009 | 04:12 PM
92smokin blacky's Avatar
I just adjusted mine yesterday and I changed the gaskets and O-rings because i had oil leakin everywhere around the valve covers and all over my exhaust manifold. So i used a whole can of engine brite and a pressure washer and cleaned it all up and now it looks good. I also painted my valve covers Grabber Green while I was at it, they look pretty cool i think. My valves were surprisingly not too bad, most of the intake valves and some of the exhaust valves were a little bit off but only by like .001" or .002". But i adjusted them anyways and it seems to run a lot better, I don't leak any oil anymore cuz i changed the gaskets and O rings and my egts dropped about 150 to 200 degrees!!! I don't know if its because of the valve adjustment or cleanin all the oil and grease off the motor, or both, but it runs a lot cooler, when i used to go down the highway at 65mph, my egts were around 800 to 900 and now they are about 600 to 750 so it helped a lot. Its nice to have a clean engine!!! Here is some pics of my valve covers painted grabber green with the engine enamel paint, I can't wait to paint my manifold and exhaust housing with some VHT black paint and get my red painted hy35 turbo on and a set of coolertubz, then it will look a lot better! but for now, I feel like its an ARCTIC CAT cummins! ha ha
Old Jun 7, 2009 | 05:33 PM
jimbo486's Avatar
92smokin, that is an interesting color. really catches your eye. i like that ASA intake as well. i looked into that a while back and they wanted something like $200 for the kit. in my opinion that seemed quite pricey for what it is. does it come with the filter? that could explain why it's worth $200
Old Jun 7, 2009 | 07:11 PM
Yeah it is interesting color isn't it, I had that color of paint layin around so i decided to do it. Yeah i think the ASA intake was $200 when i bought it last year. It does come with the AFE filter and i bought the cleaning kit too when i bought it. I think I am gonna be sellin it soon if you are interested, pm me and we will talk prices. I think I'm gonna build my own intake with an amsoil filter so I won't need this one.
West Coast
Nov 6, 2006 07:53 PM
93' Shorty
Dec 17, 2004 10:21 PM
bigbaddiesel
Jan 18, 2003 01:07 AM
Nicholas
Jan 11, 2003 11:09 AM
Paul Winey
13
Dec 28, 2002 08:04 PM
