UPgrading my PDR Hx-35
Old Apr 15, 2007 | 08:55 AM
CrewCabCummins's Avatar
I just ordered a stage 3 HX comp kit from HTT...am I going to see a big differance over my PDR 35 that I've been running? Also there is a note at the bottom of the page that say's I might have to MACHINE something?? What is it that need's to be done?...Has anyone here made this upgrade to their HX-35...........was this 275.00 well spent?
Old Apr 15, 2007 | 08:57 AM
If you have a PDR-35, then going to a Stage III is just a lateral move. They are approximately equal.
Old Apr 15, 2007 | 09:23 AM
Which upgrade should I have ordered from them??? Would the stage 4 for the wh turbo have worked?? Let me know so I can call and RE_ORDER....THANKS for the quick responce....
Old Apr 15, 2007 | 09:46 AM
rbrettctd's Avatar
STAGE III 400 hp UPGRADE COMPRESSOR HOUSING AND 60mm High Flow WHEEL - 95-02 DODGE/CUMMINS
$275.00 (housing and wheel only)
This upgrade converts your stock HX35W turbo to our most popular HX35/HX40 hybrid turbo.
From htturbos site, it is same as the hybrid, which is Piers. Looks like that is the highest upgrade they make for it. May be time to go to a hx40 or other brand, depending on your current mods.
Old Apr 15, 2007 | 10:16 AM
The only upgrade you can do is a bigger turbo like an HTB2.
Old Apr 15, 2007 | 11:33 AM
G1625S's Avatar
Would the more efficient blades of the stage IV be a benefit over the PDR compressor?
Old Apr 15, 2007 | 11:38 AM
DLittle's Avatar
I thought the PDR-35 used a 58mm wheel ?
Old Apr 15, 2007 | 01:02 PM
gman07's Avatar
Yep, it does, and the HTT Stage III HX35 is a 60mm, 6 blade wheel. However, the difference between the two will be almost negligible. It really isn't worth the money to upgrade the PDR hybrid; the money would be better spent on a bigger turbo.
Txwelder
14
Nov 11, 2007 04:28 PM
Hawkeye
Sep 23, 2003 08:22 PM
Nicholas
Mar 14, 2003 04:14 PM
1ST GEN.
Nov 8, 2002 06:59 AM
Bushy
Nov 1, 2002 10:18 AM
